- 2007 G35x manual shift having trouble
- Transmission swap options
- Spacer on 08 sedan?
- Any Superchargers?
- anyone experience with Stillen Transmission Cooler kit
- Are HFC's worth it?
- Takeda (AFE) Short Ram Intake – First Impressions
- 2008 G35 won't start!
- R2C Intake, Fast Intentions exhaust and Dyno tune …
- Stillen Gen3 Intake fittment and pics
- any turbo or sc setups for our cars yet??
- So i was bored after work on Friday.........
- Fuel Injector Service
- Throttle Body Cleaning?
- Upgrading VQ35DE vs. VQ35HR Any difference in actual gains from intake and exhaust
- Oil Gear
- Anyone else have this on their G?
- Engine Computer Unit being Replaced
- Magnaflow 11385 installed!
- Coming Soon: GReddy Spectrum Elite Exhaust
- Review: Injen Short Ram Intake
- G35X Changing Fluids - Diffs and Transfer Case
- Evap Leak...Grabbing straws here.
- Invidia Q300 WTF IS THIS!?!?!?!?
- Car jerks when it's almost hot, HELP PLZ!
- custom exhaust sound clips
- Kinetix HFC...quality?
- Magnaflow X-Muffler
- Car died on the highway. Need help from Techs
- want my tanabe exhaust louder, x-pipe or h-pipe?
- Aftermarket LSDs
- Osirus Tune
- 07 g35x Fast Intentions Exhaust
- your thoughts on these test pipes?
- which exhaust + hfc to buy ??
- Cleaned out my KN filters
- It's Heeeeeeeeere!11!1one (nx)
- Another Review - Injen SRI
- K&N Filter vs Stock Filter
- Reputable Exhaust Shop in houston
- Excessive heat from the side of my car
- Installed: Invidia Q300 Exhaust
- New Engine?
- What's the "pecking" order as far as A/M BBK brakes?
- OBD-II: which protocol do we use?
- Fast intentions vs Borla
- 2nd to 3rd shift....
- Percentage of drivetrain loss?
- Anyone with a wiring diagram, where to tap the RPM signal?
- 5AT people w/HFC, questions inside for you
- Ate the serpentine belt at 11K
- Initial Review - Injen SRI
- torn between which exhaust to get..
- INVIDIA Q300 Titanium Tip Exhaust
- What are your base run dyno numbers?
- Timing Advancement and E85 Fuel?
- Bully Dog Tuner Update Error Message?
- Lets add another intake to the mix... INJEN Short Ram Intake that is!!
- are headers really worth it?
- Another new intake coming out
- Do I need to do some reflash?
- need a solution to this CEL problem.
- To those with a Stillen exhaust
- cobb accessport vs bullydog power pup comparison
- correct A/F ratio
- does anyone has the 44590_v122b file for bullydog?
- Rough engine noise after BBGK install
- Oil Consumption
- 07 Sedan dyno numbers?
- Clicking at 3500-4000 RPM?
- Whats the best price for a FI exhaust out there?
- Will any of the aftermarket intakes make the car run lean?
- Help! Which HFC should I get?
- Injen lose the power????
- Got $500, Stillen Gen3 or Injen Dual CAI?
- G37: If your tranny has a rough downshift between third & second gear. . .
- Stillen exhaust or FI exhaust??
- Idle RPM drop??
- Strange Clutch Problem
- Quick Question regarding Dyno
- Anyone get Osiris Standard???
- Magnefine filter - trans oil cooler line question
- DynoTune @ UPREV Austin,TX
- STS TurboKit UPDATE!!!
- Anyone here have HKS Dual Hi-Power Exhaust: G35 Sedan 07-UP??
- Just ordered R2C Intake from Andy.
- Impul High Power Control Unit and Power Throttle Valves
- My Berks finally arrived, but is this normal?
- Injen Cold air Intake
- Fujitsubo Exhaust system for V36 Sedan
- Fujita air intake
- HKS drop in air filter
- GTM, Vortech, STS, APS? What power-adders out there for us?
- Stillen or Impul Headers
- Cobb tuning is ready!!!!!
- Spark Plug Replacement Interval
- catback exhaust + either HFC or TP ?
- Blitz throttle controller.
- Grounding Kits - I'm a believer.
- Flap in Exhaust?
