PDA
View Full Version : V36 Engine, Exhaust, Drivetrain & FI
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13
  1. AAM or Beks
  2. changing Diff Fluid
  3. 6mt clutch problems
  4. very rough idling at startup?
  5. STILLEN Grounding Kit
  6. Stillen Exhaust?
  7. Takeda Intake
  8. Which HFC to get?
  9. I'm NOT happy with my new intakes !!
  10. What's this and can we get this on our 07+ sedans
  11. New Tuner! Hypertech "Hypermax" for G35-G37!!
  12. Best aftermarket tune for 2008 G35?? (I searched, but...)
  13. FML now what do i do???
  14. Exhaust piping diameter ... Stillen?
  15. Calling : Stillen Exhaust Owners
  16. AWD Differential Fluid Change - which parts needed?
  17. R2c Maxxflow CAI
  18. 2009 g37 7at
  19. SxExCx's V36 Grounding Kit
  20. Question for those with a FI exhaust
  21. Driver-Side Auto-Up Window Failure
  22. Exhaust sound?
  23. stillen exhaust part# diff
  24. R2C on 07x
  25. Just installed a Fujita intake.
  26. Riverside Infiniti
  27. Another GCC spec-only option
  28. Castrol Edge vs Mobil 1 Extended Performance
  29. Osiris price drop in Standard Version
  30. Help with ECM plz!
  31. Aftermarket Camshafts
  32. Samco Radiator Hose kit
  33. OEM battery finally went out
  34. quick question about intakes
  35. water leaking
  36. What do you guys think about Greddy SE exhaust?
  37. G35 30K Service at CarZone Auto Repair
  38. 2007+ Transmission Dip Stick
  39. Finally installed the Q300!!!
  40. Got tranny replaced at 30k.. Do I still need the ATF flush?
  41. Vacuum/ howling noise
  42. whats wrong with my friend's car ?
  43. HELP!!!!! no throttle response
  44. Invidia Q300 - Review
  45. Transmission Flush???
  46. Exhaust Accessories...
  47. high idle after warmed up?
  48. Car didn't want to start for 2 minutes? :(
  49. Which is the "best" exhaust? :official:
  50. Which is the "best" exhaust?
  51. DIY TT install going on ...
  52. Bullydog GT Tuner or Powerpup?
  53. Anyone smell??
  54. Tranny Drain and Fill, 4.7 quarts needed.
  55. Can you put auto to N while driving?
  56. JWT clutch installed
  57. Best V36 power mod for the $$ ??
  58. Ultimate Mods Lists
  59. help needed now!! PLEASE
  60. Dealer tells me German Castrol Synthetic 0W30 oil is too thin!??
  61. clutch pedal on the ground
  62. Fujita Intakes and petrol consumption increased
  63. New HR internal parts
  64. Fujita SRI vs AEM CAI
  65. Weird exhaust/engine noise
  66. PROBLEM: overheating???
  67. Catastrophic Engine Failure?!
  68. Quick Question - Is it possible for an 08 350z exhaust to fit our sedan?
  69. GTM Supercharger Kit
  70. need a new clutch but which one
  71. high rpm = warning light
  72. Should I keep my HFC's on? Chime in.
  73. RPM shift light.
  74. do i need a retune with new engine?
  75. What exhaust do you guys recommended?
  76. COBB exhaust?
  77. HKS hybrid filters !
  78. RPI Ram Air inducton system for G35/37
  79. Pennzoil Platinum - TBN
  80. Stillen Catback
  81. Cooling Problems?
  82. Anyone interested in working with OPENECU group to develop G35 compatible version?
  83. Anyone has a COBB ECU upgrade?
  84. Throttle Body Help Close to Stripping Bolt
  85. G35 is tapping like a mofo
  86. Suggestions for MPG without hindering performance
  87. custom exhaust ppl please chime in
  88. How are these Dyno numbers?
  89. Dyno Sheet for my 2008 G35 Sedan
  90. need chip?
  91. For those members with HFC's
  92. Injen SRI installation issues - Need advice.
  93. Differential and Transmission Fluid Change
  94. High RPM Squeak !!! help
  95. Question w/ OEM Coupe vs Sedan Exhaust
  96. problem with my 6mt
  97. Ultimate list of engine problems?
  98. Meisterschaft Exhaust!
  99. broken axle RESULTS...
  100. ECU update and reset question
