PDA
View Full Version : V36 Engine, Exhaust, Drivetrain & FI
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13
  1. Transfer Case Dripping
  2. Idle timing issue/engine replacement
  3. Injen IS short ram
  4. fluid change
  5. Test Pipes / HFCs Issues & Problems
  6. Stillen vs Invidia gemini
  7. Port & Polish the intake manifold? Gasketmatch the heads?
  8. Service Engine Soon warning light
  9. 2007 g35x blown motor
  10. Anybody whose looked close at the block
  11. fx35/45 exhaust on 2007 g35x sedan
  12. ARK GRIP exhaust! anyone? owners?
  13. Uprev Osiris Standard vs. Tuner
  14. Just a few transmission questions
  15. Changing engine air filters
  16. 07 G35 Sedan - how to make it sound like a coupe
  17. Berk test pipes check engine
  18. Hypertech problem
  19. VB Mod?
  20. Stillen Headers
  21. 07 5 speed AT ASC acting weird
  22. Manual Trans Reverse Lock Out
  23. Transmission oil cooler installed!
  24. Constructing a CAI.
  25. Time for a new mod! HFC! Expert/Experienced/Enthusiast/Everyone's Help
  26. Gas mileage going from 08 G35x to G37x. Can owners post their results?
  27. STILLEN intakes
  28. hp upgrade
  29. Please help!!!
  30. 08 g35 sedan F.I. exhaust on 11 g37 sedan
  31. How hard is it to change the auto transmission fluid?
  32. Injen Intake Question
  33. G was running high on RPM?
  34. Ticking after oil change
  35. Stillen vs FI vs Tanabe vs GReddy?? HELP
  36. Will the Bully Dog tuner work on a G35x?
  37. Does Invidia Gemini actually exist for the sedan?
  38. Vibration out of rear diff
  39. Piping with Tanabe Medalion
  40. Used Oil Analysis on my G - sharing results
  41. Catalytic Convertor Code-
  42. Underneath steering column and dash noise
  43. Black plastic cover under engine
  44. Invidia Gemini Exhaust vs. Tanabe Medallion Touring ?
  45. 2007 G35x Sedan exhaust question
  46. Differential Swap
  47. Z-tube vs g-tube
  48. Factory oil cooler/warmer removal?
  49. Will the fuel injectors from VQ37VHR fit my VQ35HR?
  50. Transgo reprogramming kit RE5R05A-HD2
  51. Questions!!! Help
  52. Okada ignition?
  53. Revshift Intake Manifold
  54. 2008 Sedan Axle back exhaust
  55. Damage Catalytic Converter
  56. Motordyne ART test pipes
  57. Kinetix Plenum seal problem...help!
  58. Drop-in Air filters: Oiled vs. Dry
  59. Clutch, VDC ........
  60. Braille Battery Install
  61. How to center exhaust tips?
  62. 6MT software?
  63. Q8y's uprev tune results
  64. Custom exhaust on my G35x
  65. Dyno Results [Stock G35]
  66. ecu tunning
  67. cobb maf hose
  68. Stillen HFC...
  69. 08 g35x Do they make a sprint booster
  70. WTF . . my differential ! plz help me out !!
  71. Exhaust Wrap on Berk HFCs
  72. Sprint Booster & UpRev tune . .
  73. Finally got to the little Bugger!!
  74. Cold Air vs Short Ram
  75. begginer looking for help
  76. Vibration sound...
  77. Grounding Kits
  78. BB grounding kit post install
  79. Cobb tune....
  80. AMSOIL ATF drain fill
  81. Drive Belt Problems
  82. so i got my car tuned by . . ( see ya inside ) !
  83. 5AT cruising revs
  84. Down-Shift - 3rd to 2nd gear problem
  85. Tune and stuff.......
  86. AT question
  87. For sound only?
  88. FI Exhaust - AWD/RWD difference.
  89. Will swapping the Y-pipe eliminate HFC rasp
  90. Stillen Exhaust W/ HFC!? (Test-Pipes)
  91. Will New Stillen SC for VQ37VHR fit
  92. Simple Question In Regards to ECU Reflash
  93. VLSD or KAZZ for 5AT?
  94. Automatic Transmission Problems - No Manual Mode
  95. Fluid capacity for transfer case
  96. Fuel Tank Gauge
  97. Exhaust y pipe for Magnaflow setup??
  98. 370Z Y pipe on 07 Sedan?
  99. I need a help here PLZ !!
  100. Wierd clutch pedal.
