PDA
View Full Version : V36 Engine, Exhaust, Drivetrain & FI
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13
  1. Inside our throttle bodies
  2. Universal HFC's??
  3. stock exhaust noise level
  4. after changing water pump and gasket due overheat help plz
  5. Service Engine Soon - HFC/TP o2 Sensors (P0420 & P0430)
  6. Front & Rear Differential Fluid
  7. Any tips on getting more trans fluid out of a single drain?
  8. Ext. Warranty Co. Rebuilding Transmission
  9. SES light: P0420 code
  10. Hesitation/Bog/Sputter @ 3k RPM
  11. engine differences between an 07 g35 and 08 g35, also X vs RWD?
  12. Just installed K&N drop in air fitlers
  13. Diff Kick on G35 '07 AT?
  14. make a g35 into a g37
  15. FI HFC & ARK performance
  16. Trans is starting to piss me off..would a grounding kit help?
  17. Optimistic Tachometer
  18. 2008 G35X supercharger???
  19. Weird Transmission Shifts After ATF Change
  20. Those with GTM RTP . . need lil help plz !
  21. new 2008 g35xS owner
  22. Question on 1st oil change on my 08 X
  23. track time with bullydog
  24. My bad luck with CATS :(
  25. Why does my car sound like a Harley!!!
  26. need ur help on a light weight crank pulley
  27. 07 G35x sedan in Kansas City - looking for mod and tune advice
  28. Quick question for any owner of Invidia Q300 sedan cat bak
  29. 30k Service Schedule
  30. silicon intake tubes... HPS or Z1?
  31. New gaskets needed for Fast Intentions exhaust?
  32. Performance Throttle Body?
  33. Poor upshifting in manual mode
  34. My Art pipe's Update, plz get in !
  35. diameter of ark
  36. Broken exhaust hanger stud!!!!!
  37. Invidia CB Exhaust too quiet
  38. AFR Readings w/o Tune ... Safe?!?
  39. TCM (transmission control module) is done. HELP!
  40. art pipes for the x
  41. Question about ARK grip install
  42. eBay test pipes ?
  43. word of advice
  44. need advice about nitrous
  45. Idle RPM is at 0 RPM :-(
  46. overheated Berk's HFC?
  47. What's special about stillen gen3 intake
  48. Best Intake Poll!
  49. Ram Air Intake system question
  50. CEL P0420 Test Pipe / HFC - Non-foulers
  51. New ART Pipes fella here :)
  52. ART pipes + ARK catback
  53. Battery Comment from dealer??
  54. Questions about my new engine and the color of the oil
  55. Hi quick question about my exhaust!
  56. FI + AWS = Bad Idea?
  57. Gtm gtr manifolds conversion??
  58. stillen gen3 CAI installation
  59. stock intake resinators
  60. Tanabe Axel back
  61. Resonated vs Non-resonated test pipes !
  62. Is this stock?
  63. Berk HFCs & Stillen Catback Exhaust
  64. Headers for the HR Sedans ..
  65. Looking for an EXHAUST for your sedan???
  66. A/T downshift when brakes applied
  67. help with g35x '07
  68. What causes engine ticking?
  69. Exhaust install
  70. Car will not start, electrical seems to work ok
  71. resonated test pipes and HFC logevity?
  72. Invidia exhaust installed!
  73. P0420 Code Help
  74. New Invidia X pipe
  75. Transmission flush $199???
  76. Y pipe fittement questions?
  77. Stillen transmission cooler installed - have a problem
  78. **Interest Thread** BERK catback exhaust for V36 07+ sedans
  79. muffler tips?
  80. valvoline tranny flush?!?!
  81. Will an exhaust made for the x fit rwd?
  82. Which spark plug is OEM for 2007 sedan?
  83. Clutch Pedal
  84. CPO Powertrain Warranty
  85. !! Stripped Cat Bolt !!
  86. Help Needed ASAP...please!!
  87. need help
  88. my car keeps backfiring..need help!
  89. Anyone balance their clutch and flywheel assembly?
  90. Test Pipe / HFC Install!
  91. for any one who has welded in an x pipe
  92. Who has modified the Invidia Q300 for AWD?
  93. Oil pooled in throttle body
  94. NEW Takeda CAI, front mount
  95. power gains
  96. issues with low rpm on take off 2007 g35 journe sedan
  97. Has anyone done this for an exhaust?
  98. Ordered some new stuff
  99. Which differential fluid do you guys use?
  100. 6 speed count
