- G35/G37 coupe midpipes
- Borla Exhaust System Fits 2008-up Infiniti G35 Sedan (with 3.5-liter engine)
- Nissan Power Pup Bullydog - First Impressions
- Weird throttle response
- Radiator fan
- Exhaust system . . . need ur help urgently !
- Magnaflow cat-back exhaust.
- redlining
- FI or Stillen?
- Ordering Uprev Osiris Standard tomorrow!!!
- STS turbo kit interest anyone?
- Exhaust Hangers
- RPi Intake Scoops and Exhaust
- Which one to get Technosquare or Uprev?
- New Hi-Flow Cats for the G
- Serious Hesitation with Berks???
- TECHNOSQUARE or UPREV?
- Exhaust Depot y pipe?
- question for those with technosquare reflash.
- How to finish my muffler delete?
- Dyno numbers
- Next Mod: Sway Bars or Intake?
- Stock exhaust drone
- K, need honest, serious input on the grounding kits...
- Clutch acting differently sometimes
- What are the cons of removing exhaust Heat shields?
- Exhaust Heat sheild Locations?
- Cleaning Stillen Gen 3 filters
- another ECU upgrade option
- New Resonators?
- FI HFC Gasket Info?
- Has Cobb died on us???
- Any independent dyno on Stillen 3G???
- Y pipe
- Injen CAI Dyno results!
- OEM Cat Removal SUggestions?
- Custom Exhaust Question
- Best sounding intake
- Anyone here got the Berk HFC from group buy?
- Replacement JWT Pop Charger filters
- hfc and test pipes
- H Pipe
- Stillen Gen 3 Intake for 07+ G35
- Invida Q300 exhausts Anyone?
- 07 G35X Auto Hard Shifting into 3rd
- Technosquare reflash+dyno
- Would this work on exhaust?
- Hissing sound after HFCs
- New Clutch
- closest sound to coupe exhaust?
- Best aftermarket clutch?? 2007 G35S
- Check Engine Light Ghost Readings
- So... my serpentine belt gave out.
- Unable to shift into 5th
- Looking for a HKS Cat-Back Exhaust
- Adjusting muffler/exhaust drop
- K&N Typhoon CAI vs Stillen 3G CAI for '07 G?
- K&N Typhoon Intake 08 g35
- STILLEN G35 Sedan Gen 3 Intake Released
- Service Engine soon light
- Question on radiator
- Official "get the US spec fujitsubo exhaust into production" Thread
- COBB TUNING or TECHNOSQUARE?
- Exhaust Control Valve???
- 2008 Gx Missing beat - Engine Timing off
- engine collant type + rattle
- Carbon Air Intake? Japan!!! Is this work? HP gain?
- Reprogramming ECU settings
- Does Y-Pipe(Ichiba) and other aftermarket Y-Pipe's fit our cars?
- Forced Induction?
- Black Betty Wires
- R2C air intake
- 2007 G35x automatic transmission problem?
- Where to find K&N Typhoon?
- Driver sport mode stuck - won't shift up or down
- Stillen Gen 3 Intake Pics and Vids
- Manumatic Mode / DS Mode NOT WORKING
- Anyone with Tanabe Medalion Touring Exhaust
- Stillen G3 intake anyone??
- Another satisfied Black Betty customer
- Black Betty Ground Kit
- Stillen Gen 3 for the sedan, (g37) is out
- UpRev ECU Upgrade
- Grounding Kits and Warranty
- Young Exhaust system?
- Idle vibration
- exhaust/muffler tips
- Can we use the 350z's intake since our motors are the same?
- Stock exhaust vs Aftermarket exhaust experience and thoughts
- Project True Dual's with/HFC's
- stock diameter pulley install
- Update from UpRev on Osiris
- Second time SES light came on with only HFC's!!!UGH!
- When I shift the car sorta kicks?
- TS Reflash for 08 G35
- Do HFCs from the coupes bolt directly onto our sedans?
- Stock exhaust with X or H pipes?
- Stillen vs. K&N intake??
- Technosquare ECU Re-Flash
- Resetting ECU
