PDA
View Full Version : V36 Engine, Exhaust, Drivetrain & FI
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13
  1. FI question
  2. Service Enging Light "P0084"
  3. Help! Trouble installing Hi-flow Kinetix Cats
  4. Anyone heard of ISOPerformence?
  5. A New Exhuast?? -- Wilson Exhuast
  6. Engine hisses when shifting at high speeds..normal?
  7. Amsoil Severe Gear
  8. Manual transmission oil
  9. Pictures of motor + transmission mount?
  10. 3-5psi electric supercharger = 10hp for $200
  11. Russian's First Stillen Supercharged G37x sedan!!!
  12. Found a very cheap Intake for 07 g35x
  13. Best intake for 07 g35x????
  14. rpms very high after replacing A/C unit
  15. JWT cams
  16. click sound when car accelerate
  17. Seized Flywheel
  18. wierd idle
  19. Motordyne ART query
  20. oil not recommended
  21. Designing a new style intake box
  22. anybody else seen this?
  23. 3 options would like opinions
  24. invidia gemini?
  25. ECU tuning
  26. Intake manifold
  27. Question about changing transmission fluid
  28. 2007 G35S Sedan Motor Mount Question
  29. Engine sputters when really cold out..this normal?
  30. Oil Cooler for going forced induction
  31. magnaflow 11385 plus HFC's on stock exhaust?
  32. Engine turns on but can't drive.... n e thoughts?
  33. Exhaust question... Power gains!
  34. Sport Cat Gone Bad?
  35. Rough idle? Or exhaust?
  36. Forced Inductions: SuperChargers and Turbochargers Questions
  37. knock off Tanabes
  38. Exhaust help and ?
  39. G36 coupe exhaust on a g35x
  40. Magnaflow 11385
  41. FI HFC with stock exhaust
  42. Looking to Buy Used Stillen cat-back exhaust for 2008 G35
  43. Noob exhaust question
  44. Stillen Headers & Exhaust
  45. quick question
  46. cam position sensor
  47. Just installed Stillen Exhaust
  48. HFC Installtion Cost
  49. Thoughts/Help on a few issues???
  50. Getting an AUTO out of part after startup?
  51. Stillen Gen3 Intakes
  52. Replacing clutch soon
  53. Hmm Which HFC
  54. Injen SP1997 Cold Air Intake for 07 G35 Sedan
  55. Injen SP1997 Cold Air Intake for 07 G35 Sedan
  56. Injen SP1997 Cold Air Intake for 07 G35 Sedan
  57. Steering Column
  58. Invidia Gemini vs. Custom Magnaflow setup
  59. Coupe Exhaust fit sedan?
  60. HFCs / Test Pipes Gaskets...
  61. just installed dual JWT pop chargers
  62. looking to buy used tanabe exhaust
  63. Clutch Engagement Point Changes
  64. Invidia q300 catback exhaust g37 09+ sedan v36
  65. Help! Magnaflow?
  66. Stillen Supercharger
  67. Y Pipe 2.5 To 3'???
  68. Mobil 1 0W30 lab analysis
  69. ARK Performance G35/G37 07-On Sedan Catback
  70. Which Tuner to buy!
  71. Hard downshift into 1st, no rev matching - solved
  72. Magnaflow
  73. DS mode only works when cold, ouch out of warranty!
  74. low voltage???
  75. Fast Intention Exhaust
  76. My serpentine belt squeals like a mofo...
  77. Does anyone have an aftermarket short throw shifter?
  78. MOD: Make your X 100% RWD. NO JOKE
  79. Engine Ticking Noise
  80. Custom Tune for mods
  81. VDC Help Please
  82. exhaust outlet inlet
  83. What's the difference between a regular and 100% synthetic oil filter?
  84. What is the best exhaust??
  85. Wire tuck
  86. Help choosing exhaust
  87. Spark Plugs for G35 2008
  88. Technical info regarding rear differential
  89. Auto tranny manual mode
  90. COBB '07-'08 Post MAF Hose
  91. which cai stillen g3 or injen cai
  92. Differential Fluid Change and Warranty concern
  93. Weapon R intake questions
  94. Technical question about Throttle Body voltage readings
  95. Gains on 2007 G35
  96. Steering Rack Leaking
  97. UpRev Cipher issues?...
  98. Short Ram Intake
  99. Cleaned TB's, throttle is acting very strange
  100. Exhaust Bolts/Nuts/Gaskets
