- AT upgrade possible?
- 6MT 1st gear sounds
- REQ: Auto tranny DIY
- diff swap instructions on a 2004 AT sedan?
- Jim Wolf clutch and flywheel going in tomorrow!
- Question about noise in clutch???
- 6mt Final Drive gear ratio for 5at.
- Considering new clutch and flywheel...help
- short shifter install
- Drifting Damage?
- Shift Noise
- Nismo Gt Titanium shift knob
- 05 Tranny Program in 03 Coupe AT
- Dealer Pricing on Diff Oil and Tranny Oil Change
- Engine / Transmission & Diff Oil Question...
- Differential Fluid Change
- Nismo GT-Titanium Shift Knob
- AT Tranny fluid Question
- can the 5AT manual shift be reversed?
- Tranny grinds in 3rd. Infiniti wont help!
- 350EVO 3.9 final drive vs OEM 3.5 chart
- VDC: Toggle Switch for Yaw control?
- Installing an LSD
- B&M short shifter??
- Final drive gear.
- Tilton Clutch/Flywheel Combo
- 2004 5AT Coupe hesitation off the line
- Anyone W/ B&M Short shifter?
- Rear end gear changing? anyone do it yet?
- Does anyone have the JWT Clutch set up on here?
- brake light/slip/atc problems???
- how does your clutch feel? firm or soft?
- clutch problems
- Anybody heard of diff fluid company (LE Inc.)?
- Q: Nismo GT Ti shift knob
- Sparco Techno Shift Knob
- Mechanical LSD, anyone?
- clutch problem
- open diff to LSD swap
- Tranny Swap
- trans problem
- Diff Oil Recommendations?
- Anyone get rattling sound with JWT clutch and Fly
- G35 Differential Type: Open or Posi?
- -- Quaife LSD -- ... want one?
- Clutch Arm Modification?
- Rear Differential Oil changed (A MUST DO) READ!
- Shift Kit?
- Nismo Flywheel vs. UR Pulleys?
- Clutch replacement time
- Need help guys
- Throwout baring
- 6MT Problems and Dealer not wanting to fix
- self checking transmission fluid
- clutch noise/vibrations
- Group Buy for Valve Body and Torque Converter
- Getting a new tranny
- gears
- Auto Tranny Shudder
- OK to switch to diff brand of syn oil?
- Manual trany oil change info
- Clutch adjustment?
- Open rear end to VLSD swap ?
- To Those with Torque Converters
- Rogue Enginering Shifter, Need suggestion ><
- 350EVO 3.9 final drive review
- Missing/Grinding Gears... HOW BAD?
- Auto Transmission Fluid
- Transmission Slip
- Clutch whistle/honk noise
- Anyone having clutch/tranny noises on stock 6MT?
- Manual mode and D mode differences?
- new shift knobs ? ... or...
- HELP MODIFYING 5AT MOMO SHIFT & OEM Leather Boot
- 3.9 final drives are in
- The last chapter of my 6MT problems...
- Cheapest NISMO LSD yet
- 6MT OWNERS NEED YOUR HELP ASAP
- Rattling noise in neutral?
- B&M short throw shifter
- 6mt tranny problems?
- Stillen AT Valve Body
- HELP: Shift Knob BOOT for 5AT w/MOMO shift MOD!!
- Quaife LSD..available yet?
- What the heck is going on !!??
- Tranny Oil Cooler for 5AT Sedan
- 3.9 final drives....350evo.com
- 5AT SHIFT NOB
- New Shift Knob
- Synth oil in 5AT trany???
- 2ND TO 3RD GEAR
- JWT Flywheel/ACT Clutch Installed
- Is Churping thru Gears BAD?
- Sedan 5AT upgrade
- Changing Manual Tranny Fluid
- 2003 G 35 Sedan auto
- clutch noise???
- Torque Converter?
- B&M Short Shifter
- Does TS flash do TCM update
