PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. 11lbs flywheel? yes or no?
  2. Ticking\Chattering Noise from Engine area FIXED!
  3. Clutch recommendations
  4. Heres a curious vibration. tell me what u think
  5. 03 g35 sedan 5/AT grind
  6. HELP: I broke my clutch ignition switch?
  7. Just replaced clutch now it won't release!
  8. Upgrade 5AT torque converter/stall? Possible?
  9. 2 clutch or not 2 clutch that is the ques.?
  10. Short Shifters? which do you prefer?
  11. covered under Warranty? wheel bearing?
  12. Help with flywheel?
  13. BEARLY replaced clutch a year ago and its out??!!
  14. **Clutch Issues!!!
  15. Another tranny question
  16. Question about exedy and findanza flywheel from ebay
  17. trans and diff fluid...
  18. anyone have a diy tranny removal?
  19. Take Care of Your Clutch--How to Prevent or Cure Clutch Pedal Issues
  20. Clutch bleeding
  21. Need your help...no power upshifting...??
  22. AT check light and service engine soon
  23. 6mt tranny problems
  24. how hard is a stock clutch?
  25. question about the X transfer case
  26. Flywheel "Hot Spots"???
  27. How do you know if you have lsd?
  28. Best replacement clutch/flywheel?
  29. Burnt Clutch
  30. Traction control/ slip light coming on??
  31. 4.083 final drive question
  32. 5AT question
  33. 350Z Flywheel compatible?
  34. Have any of you put a non-Nissan transmission into your 6MT?
  35. Need clutch and flywheel help
  36. Clutch chatter
  37. Automatic Transmission flush
  38. Lightweight flywheel help
  39. Vibration
  40. Clutch Pedal Vibration / Chatter Question
  41. clutch slipping, anyone w/ experience changed theirs?
  42. Clutch Info
  43. Transmission and Rear-End fluid change
  44. AWD and Transfer case problem
  45. G37 pumpkin?
  46. Help!!!!
  47. 5AT switch to 6MT
  48. I Absolutely HATE this transmission
  49. G 35 clutch slippage
  50. 04 G35 6MT (5th gear grind, stiff clutch)
  51. Another MT noise when cold thread with fix....
  52. My Clutch is going Dead!!!! WHHHYYYY
  53. Question on RPM gauge
  54. New G35 owner, weird clutch issue?
  55. Clutch Engagement- QUICK QUESTION-HELP!
  56. Gears locked up....need help!!!
  57. New clutch and flywheel and car won't start!
  58. How far do you Clutch In??
  59. Drivetrain Vibration
  60. Most reliable trans AUTO OR MT
  61. Auto Tranny Problems
  62. thinking of going with Final Drive
  63. part #for 2003.5 coupe slave cylinder??
  64. :: Carbonetic clutch - READ ::
  65. :: Carbonetic clutch - READ ::
  66. Dealer Says I need a new clutch
  67. Transmission flush at 30k, need it again at 50k?
  68. Amsoil differential gear lubricant
  69. Will a 06 350z tranny(6mt) fit in my 03 G35 Sedan(6mt)?
  70. tune vs gears
  71. Planning to buy Coupe shortshifter for my sedan
  72. Clutch Munched Bad
  73. Carbonetics twin disc clutch????
  74. accidentaly shifted gears from D to P while in motion
  75. Clicking noise...HELP!
  76. Wet Shoe + Clutch Pedal
  77. Stupid question - flywheel/clutch combo
  78. Transfer fluid drain/filler plug gasket part # ?
  79. Reviews? Nismo SS clutch line
  80. Premature clutch wear-what replacement?
  81. Z1 Clutch have PREMATURE WEAR
  82. Clutch Fork Pivot Ball part number request
  83. Powertrain hesitates
  84. transmission. 5AT
  85. CD009 Transmission and Clutch install - pedal adjustment help
  86. Problem: SLIP, Parking Brake & VDC Off Lights On
  87. Who has upgraded their Final Drive
  88. My DIY transmission fluid drain & refill. Redline vs. Nissan
  89. clutch problem, please help
  90. Throw Out Bearing, Lube?
  91. slip
  92. Is this normal? Tranny
  93. Upgrades for 5AT
  94. can you change the diff fluid with ramps on the rear
  95. Rear end question...
  96. What kind of replacement clutch kit should I get?
  97. 2003 Sedan 5AT looking to doa 6sp Swap
  98. Clutch problems
  99. should i change my flywheel???
  100. wheel bearing under Power/Drivertrain??
