- Can't get transmission back in
- How bad is it to ride in manu-matic?
- Tranny/Gear Box Question
- 04 5at rear diff
- syncro?
- 3.3 to 3.7 question
- Just out of curiosity: Super Tech ATF?
- VDC and Slip Problem
- tranny slipping
- Clutch Noises
- Ring/Pinion Question
- JWT Clutch Pressure plate problems...!!!!
- RPS Clutch/JWT Flywheel will this combo work???
- Clutch Noise When Shifting at higher rpm
- DIY 03 G35 Coupe 5AT to 07 G35S 5AT differential swap
- Diff oil: 75w-90 or 75w-140?
- '06 5AT jumps hard when put into gear
- 6MT-very hard shifts out of neutral
- Diff cover stud bolt
- 5th gear grinding at 87mph-109mph wth?!?
- Transmission rattle noise
- 03 g35 coupe! I might need a catalyt converter, please read
- Difference in the 04 AT5 trannies
- STILLEN Transmission Valve Body Upgrade
- Auto Trans keeps G35X 04 to start
- Clutch Problem (this one is different, i swear)
- Throw out bearing?
- WTF? 03 5AT Coupe with VLSD?
- Need New CLutch Advice
- What rear????????
- 5AT gargles at low-speed 1-2 transition
- When does the torque converter lock up?
- NISMO Short-Throw Shifter PLAY
- AT transmission issue Please help
- AT to MT swap list. please help
- Need clutch advise...
- Mixing clutch fluid?
- Does a Hr OEM clutch and flywheel fit a DE motor?
- Rough noise at speed - intermittent & variable
- new clutch and flywheel put in today and..
- Differential Swap 6mt
- 03.0 5AT just sliped REAL bad
- transmission shifts hard with bass
- clutch/flywheel help
- 05 G35x autotrans prob
- Final Drive for 2007 5AT with sport package??
- can't change from D to manual shift
- Transmission Flush?
- Changed Flywheel, Now Car won't run.
- G35 Halfshaft the same as a 350?
- Strange Transmission Problem (A/T)
- HELP!!! Transmission problems
- Transgo Valve Body Upgrade DIY
- Rear Diff fluid question ....
- Do i have a VLSD?
- Differential Drain Plug Dilemma
- strange noise from tranny?
- Need help deciding on a new clutch...
- Should I change my trans fluid at 90k for the first time?
- Vlsd Motul gear 300
- Mobil 1 syn ATF ok for AWD Xfer case?
- Clutch or Tranny or Weather Temp?
- Not chatter on low rev but gear noise
- I NEED EVERYONES OPINION! Transmission Fluid Service.
- Had my Transgo shift kit installed today
- The skinny on "axle click"
- RPM's at 80 MPH
- Clutch Trouble
- 05 G35 coupe - Loud whistling noise when driving
- 05 g35 clutch stuck to floor
- 5at gotta have a SprintBooster!
- Tranmission noise
- transmission question
- Experiences with Exedy OEM clutch?
- Royal Purple Transmission Fluid
- Any experience with Exedy OEM clutch?
- What's a good clutch
- Top Tier Gasolines
- Nismo shift knobs - how do they change the feel of shifting?
- Confused about the stock pumkin, can some1 help me out?
- Hard to shift cold!
- 2005 A/T Sedan
- HELP! - dealership wants $1,000 to replace front driveshaft
- Is my clutch going? 05 coupe
- The Math-Trans Fluid Drain&Fill
- stricky suggestions for drivetrain section
- Another tranny issue thread(no i did not sleep with one)
- AT Trans Issue PLEASE HELP!
- Gears 373 410 ????
- Need Rogue Short Shifter Installed. Orange County
- Wrong coolant :\
- Automatic Transmission rpm stuttering when slowing down
- 6MT Transmission Compatability
- 370z LSD
- Two times Tiptronic wont let me change gears
- looking for new clutch
- 2005 G35 Sedan AT
- Transmission swap question...
- Help stuck on neutral
- rear 3rd member swap options
