- Synth oil in 5AT trany???
- 2ND TO 3RD GEAR
- JWT Flywheel/ACT Clutch Installed
- Is Churping thru Gears BAD?
- Sedan 5AT upgrade
- Changing Manual Tranny Fluid
- 2003 G 35 Sedan auto
- clutch noise???
- Torque Converter?
- B&M Short Shifter
- Does TS flash do TCM update
- Drilled Aluminum Pedals for 5AT
- 6MT Problem???
- Transmission fluid level
- Are all shift knobs created equal?
- LEVEL 10
- manumatic question?
- squeeky clutch
- Question about Transmission noise?
- Clutch install price?
- VDC 2 sensitive??
- G35 5AT Lag in Manumatic UP Shifting
- rogue engineering
- Torque converter question
- Crappy Tranny
- 6MT vs 5AT
- Why the 5AT lags when shifting
- Degree of difficulty in swapping out flywheel?
- Torque Converters
- flywheels
- Trans sticking???
- AT Shift Knob for Coupe
- What's going On ??
- Drivetrain Loss
- 1st & 2nd Grinding
- Level 10 PTS Shiftronic™
- 5AT hissing sound when in MM mode
- Short Shifter Poll
- Another VDC explanation please?
- GTechComp Impression/ shift technique?
- VLSD
- B&M shifter problems - getting returned
- Tilton 8lb flywheel & clutch installed
- VDC Memory Anyone??
- clutch height
- Gear Ratios & Gas Mileage
- B&M Short Shifter...
- Short throw Shifter
- 5AT Tranny on the coupe
- Tranny Programming 5AT
- changing rearend gears?
- G35's Tranny
- starting the car and switching gears
- I recommend people not to change to Amsoil Tranny
- Manumatic lazy shifting
- For 5AT G35 Owners (transmission question)
- Who here doesn't have tranny problems, but
- Problem with Cruise Control, anyone?
- People with Amsoil 75w90 in 6MT...
- COUPE rear AXEL
- Hints on Installing Rogue Shifter
- AT manual mode shifting problem - help =)
- Automatic to Manual conversion
- FlyWheel Mod apply to Sedan w/Auto?
- Lower Gear Ratios
- How to fill the 6MT back up?
- Quaife LSD
- traction system
- car won't move or accelerate
- JWT Flywheel...anyone try it yet?
- transmission fill
- Questions on changing MT and Differential Oil...
- Stock LSD, Do I change?
- STICK GOT STUCK?
- Question for the 6MT's
- Install NISMO LSD, and you will die...
- Anbyody have 6mt tranny fluid change info?
- Anyone found a decent short shifter for the 6MT?
- Another 6MT Tranny question
- Anyone switch to synthetic manual tranny fluid?
- how can i make shifting less knotchy
- My 5AT now has NISMO LSD!!
- Rattling in the clutch
- MADD - Torque Converter, Part II
- 3.917 rear ?
- Bad.. Grinding gears at 22k
- Stillen 5AT Valve Body Upgrade....
- Clutch Chatter
- Clutch effort
- Rogue Engineering Short Shifter Installed
- Hey Guys - Need your help
- NOISEY! NISMO Flywheel,Pres.Plate,Clutch.HELP!
- My T/C & V/B Mod Feedback
- Has anyone put a synthetic in their tranny?
- Change 5AT to look like 6MT
- AWD
- CVT-M8 Tranny for US Mkt G35s...?
- Quaife ATBD for the G35...?
- Got My Torque Converter ... and a New Problem...
- normal for clutch gets hard?
