- 6mt swap quick question
- Clunky gears shift at low rpms
- Leaking sensor seal
- Transmission Drain & Fill
- Transmission fluid change
- Help with Z1 Pulley Install
- 06 5AT Stuck in 4th
- Redline vs OEM
- Slave cylinder problem
- Oil Pressure Switch thread pitch?
- G35x Sedan Rear Wheel Bearings
- rough acceleration
- Car revs strangely, but not a clutch issue?
- OBD2 Wireless Shift Light
- Transmission
- Motor swap gone wrong? Flywheel not fitting AT crank
- 08 g35 rough transmission shifting
- Rear Diff Bushings & TransGo Installed
- im pullin a bunch of tranny codes
- A340E possible in G35?
- 5AT - 6MT swap left me with ECU code, help?
- TCM/Valve Body/Front Brake Solenoid
- Rear differential
- Car bucks when accelerating after replacing automatic transmission
- JDM trans
- Engine swap now transmission makes weird noise.
- AWD not working?
- 3.69 front diff on vq35de
- Flywheel bolts length?
- Transmission tailshaft bushings?
- RMS replacement
- TCM reprogram required?
- DMF failure symptoms?
- Is a TCM reprogram needed?
- question about ATF drain and refill..
- 2005 g35 atx reprogram
- Diff differences
- ATF shooting out of bellhousing inspection cover
- Tcm p1757
- (relatively) inexpensive LSD upgrade?
- Chatter ONLY during take-off? (18lb flywheel)
- Mines racing auto shifter mod harness...
- arerthe rwd and awd transmissions the same.
- Steering binding
- 6mt stuck in gear
- First time transmission install, busted trans pump?
- Transmission swap
- How much HP for Transfer Case/Transmission
- ZSpeed Quiet Disc vs Southbend Quiet Disc vs Z1 Mid weight
- G35x Driveshaft question
- TCM in Transmission
- What is the correct Transmission for my G35
- Are the 06' coupe and sedan transmissions the same?
- 2003 Transmission ??? HELP
- Shifter assembly 2005 Infiniti g35x sedan
- A Question About Clutch Replacement
- Diff noise
- Car won't start or park after towing
- I need help with check engine codes and solutions
- which Final Drive will make up lost power?
- P0024
- Clutch Setups
- Vibration from the 6MT shift knob
- A/T Transmission 1st gear engagement issue
- 08 350z diff into 05 G35 Coupe
- Clutch slipping or....?
- G35x to G35 RWD conversion
- throwout bearing/sleeve question.
- Help me diagnose my clutch/flywheel problem?
- Does the Z1 Mid weight flywheel chatter a lot?
- 06 5AT Final Drive Be all end all
- Transmission Swap - CD009 :)
- P1730 Code, Please Help!
- reverse lights
- 2003 G35 Coupe Manual Transmission/Clutch Help Meeded
- Howling noise at 40 MPH
- Where to drill precisely drill holes for clutch pedal and clutch master cylinder
- Ticking noise at idle after head gasket and new chain
- Shift linkage location
- 6MT - General question involving lugging engine while launching/getting rolling
- 6MT issues with MULTIPLE replacement units, a few other questions about this gearbox
- Differention and transmission fluid opinion
- P0850 code
- 91 gas?
- Differential bad or worse?
- 2004 clutch recommendations
- 06 g35 mt6 making clutch noises
- speed sensor?
- Performance Drivetrain
- Rpm spikes and car loses hp
- Transmission Issue..
- Clutch Issues!!! Need Help!!!
- How to remove torque converter bolts
- 370z Nismo Diff Final Drive
- South bend stage 1 clutch?
- flywheel replacement
- I think I may have smoked my transmission
- The infamous click.
- Bank 1 = Lean, Bank 2 = Rich
- G35 transmission fix
