PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29
  1. Revo Technica Short Shifter
  2. Hard Shift Is it Normal 5 A/T
  3. Lagging trany.
  4. which clutch and flywheel?
  5. Is this the clutch "sticking?"
  6. Anyone get a fix for the notchy shifter?
  7. 2 little questions! :D (clutch questions)
  8. Have a clicking or ticking noise coming from tranny
  9. Anyone switched to synthetic transm 6MT oil?
  10. Rear diff oil weight
  11. Automatic Transmission Upgrade options?
  12. Synthetic Manual Transmission Oil
  13. Transgo Valve Body / Edge Racing TC
  14. Gear grinds on 3rd... no matter what O_O?
  15. question about transmission ?
  16. Your experience with the SFR Valve Body upgrade?
  17. best aftermarket clutch and flywheel for g35 coupe
  18. 07 6mt revup motor clutch feeling
  19. G37 Transmission Swap
  20. Cusco RS LSD and Technosquare...
  21. Cusco RS LSD and Technosquare...
  22. Clutch Problems Need Help!
  23. Infiniti and CVT transmissions
  24. Transmission Fluid Question
  25. Need DIY Help - A/T Fluid Drain/Refill
  26. AWD 04 coupe
  27. Shifting: clutch to floor?
  28. Checking AT Fluid
  29. I just had my clutch changed and now it's shaking like crazy.
  30. Will RPS flywheel work with JWT clutch?
  31. 05 6MT clutch pedal sticking to the floor
  32. Shift knob removal possible damage
  33. Exedy clutch with XTD flywheel?
  34. How many of you 6MT drivers replace the clutch on dealer's advice
  35. Help car wont move!!!
  36. clutch burning smell going uphill?
  37. Manual Mode seems a bit hesitant
  38. Burned out clutch. :(
  39. 04' 6MT Tranny replacement question!!!!!
  40. overdrive manual
  41. Tranny input shaft responsible for rattling noise in an '06 MT?
  42. how to disable YAW sensor???
  43. Clutch/Flywheel install
  44. weird noise coming from the rear
  45. Clutch question ?
  46. ACT Flywheel vs. JWT flywheel
  47. ACT Clutch vs. Exedy Stage 1 Clutch vs. JWT Clutch
  48. havin Problems with 5AT
  49. Exedy Stage 1 Clutch kit and ACT Flywheel
  50. DIY-Clutch Line
  51. Burning Clutch Smell!!!
  52. Popping sound coming from rear????? Help
  53. Cusco RS...difference between G and Z?
  54. GMT tranny oil
  55. Chatter when turning G35 MT Off
  56. Need some advice
  57. Clutch Feeling
  58. Electronic Throttle Sensor?
  59. How much to install a clutch?
  60. Doing a 6spd conversion, need help.
  61. 5at problems. No reverse
  62. AWD for my coupe!
  63. Stillen VB upgrade - Pooched!
  64. stock clutch and flywheel
  65. fr/b solenoid in AT transmission bad
  66. Clutch effort question
  67. Rear Diff Fluid Question
  68. clutch slipping
  69. High Horse power Clutch Opinions?
  70. 6MT chatter question
  71. HELP: 04 COUPE trans problem
  72. 5AT Manual Shifting Technique for increased Tranny Life?
  73. Flywheel?
  74. nismo differential
  75. Who sells Nismo Braided Steel Clutch Line.....
  76. Clutch got shorter and i need to puch the shifter into gear
  77. i think my transmision is going need help or my clutch
  78. i think my transmision is going need help or my clutch
  79. Clutch problem
  80. transmission oil
  81. New Clutch Kit And Flywheel
  82. The "S" on ATs
  83. Clutch is burned out!!! Just bought g coupe with 28k miles!!
  84. Lowered Clutch and now won't shift
  85. Shifter Vibration
  86. Clutch replacment
  87. 5AT Quaife install - I need 3.5 FD Gears
  88. Want to improve shift response in your 03/04 sedan?
  89. Transmission filter
  90. 5AT Manual mode - downshift miss?
  91. What to do w/ oem vlsd and 3.5 fg?
  92. 07 6MT - clutch failed and left me stranded
  93. Clutch engage fix: D-wolf clutch kit exposed and
  94. drivers at 6mt, "skipping gears saves gas" ???
  95. Rear Diff Oil Change
  96. 6MT Power Limits????
  97. Brakes and Clutch *Need help* *PICS*
  98. Wheres the transmission bolt?
  99. another trans ?
  100. Nismo Pilot Bearing discussion...
