- Clutch noise during cold start
- Clutch noise during cold start up
- drive shaft seal is leaking???????????????
- ATF, differential, transfer, coolant fluid questions...
- replacing syncros
- Matic-J
- $12.50 for nissan transmission bottle??
- Cheapest to replace clutch?
- Has anyone had their clutch replaced?
- Shifter problem or transmission?
- Please help, clutch question.
- Transmission Removal Question
- Drivetrain issue?
- What you think of this Clutch? Worth IT?
- Clutch gone?!?!
- Clutch Recommendation
- Not good! need experts advice plz
- Installing ACT HDSS clutch and Prolite Fly
- Will 350z short shifter fit my 06 sedan?
- EXEDY clutch
- What gear oil for an 04 g35 MT?
- Am I having a Transmission issue or is it just the COLD weather?
- Do I need a new flywheel?
- Car stuck in Drive! HELP!!!
- Messed up Clutch? Please help
- How smooth should it be?
- difference between 009 and 008 trans?
- Does the 5AT automatically downshift in manumatic mode?
- Transmission Problem..HELP
- 6th gear just started grinding??
- Short shifter ruins your XMSN!
- Chip on my clutch
- High clutch engagement
- Transmission problems??? help!!
- Clutch
- Differential Mount Bushings? Help please!
- "Clunking" Noise at take-off!
- Recommend website for Nismo Flywheel/Clutch
- Transmission oil
- Bought a 2004 G35 6MT Coupe @ Dealership and Clutch ALREADY Died!
- Leaking driveshaft section
- PLEASE HELP! 03 G-AT Problem
- motha F**k sh*t. Clutch is acting up again...need more immediate advice
- Clutch Question
- AWD maintenance costs
- AT question
- Very Weird Problem. 03 G35 auto wont accelerate in 3rd.
- HELP.. Sticky(ing) Clutch
- Has anybody installed LUK Clutch and Flywheel combo?
- Automatic into a 6MT
- Aggressive shift mod for 5AT sport
- 3...2...1... Launch
- Changing the Gear Ratio on Your Car
- what is up with rattle noise on 1st-3rd gear?
- Competition Clutch
- should i let dealer install my jim wolf clutch/flywheel?
- 2004 g35 coupe clutch problem
- which fd gears work with 03 5at?
- 6MT rear in a 5AT G35 coupe question.
- WOT Box/Launch Control
- Clutch Noise
- New Clutch
- Clutch Recommendations
- clutch / flywheel question
- So are there no aftermarket clutch without chatter?
- Thinking of changing clutch
- Axle Click Repair Success
- Squeeky Clutch
- Need a clutch
- Jammed shift fork???
- Clutch Pedal mods; What the difference
- Clutch pedal question/problem
- 03 Tranny problem?
- OEM vs Stage 1 Clutch kits
- Clutch or Trans problem????
- squeaking clutch
- Hearing the gears shift..
- How do you tell when your clutch is almost gone?
- Initial curious questions... I want to upgrade clutch? and what fluid to replace with
- Dealership wont warranty my clutch..now what?
- CLICKING NOISE for AT
- JWT Clutch and Flywheel Chatter Issues..
- Auto transmission fluid change
- gear box problems
- My tranny is slipping...is it covered under warranty? could be clutch or rear seal
- swap out
- my g35c is messing up again...clutch?tranny? and canont put more than gallon in tank
- Better shifts in 06c MT ??
- Paddle shifters for 2003 with OEM steering wheel and OEM LOOK
- Clutch Problem
- HELP: Clutch vibration on release
- When putting it into 2nd gear!!
- Trouble shifting into 1st from neutral from dead stop
- squeaky clutch / soft spot while depressing
- Rear end gear ratios. and larger tire wheel combos
- Slip light on right before redline
- clutch/tranny issue
- Anyone remove their clutch damper?
- Finally had it with this clutch
