- THIS Sound! :)
- o2 spacer???
- SxExCx Custom Intake Mod using the G Box
- BEST HFC or catalytic converter for G35 sedan?
- Best exhaust system
- Berk HFCs Installed-Need Help!
- berk hfc
- Full exhaust choices
- Gasket
- Coupe mid-pipe resonator
- Dynomax VT muffler
- Top Pro 1 Exhaust Illegal in CA?
- My motordyne exhaust has a leak...
- A/C rough idling?!?!? Help
- MD exhaust extensions?
- HELP is this a vacuum leak?!?
- Quick dumb question
- BERK HFC just my personal opinions
- Car accelerates up to 20 mph and wont reverse. codes P1078 P1084
- z1 high flow cats
- Question on exhaust gaskets
- invidia gemini exhaust with FI Resonated HFCs
- buying used hfcs, worth it?
- Headers question or help
- Check engine light, Loss of power after removal of Fuel rails ad injectors
- Need help pls
- White Stinky Smoke. HELP!
- md spacer whistle
- Single cat
- HFC Berks, MotorDyne OR Invidia
- Twin Turbo - What exhaust are you running?
- CEL code need to be reassured
- Beluga Exhaust
- New exhaust gaskets still leaking..
- NEED HELP; Car won't stay on after Valve Cover Gasket replacement
- G35 Stillen with ART Pipes
- New 03 couple owner. Do I have a spacer installed?
- Info: People with MotorDyne 5/16 Plenum Spacer and GTSpec Tower Strut Brace
- Overheating help!!!!!
- TDX v2 and drone
- Direction of exhaust hanger on 04 sedan?
- Spacer + mrev2 on non-revup with vortech or?
- Art pipes?
- New Headers Cost Estimate
- Test pipe advice
- Best exhaust for 2006 g35 sedan?
- CLosest to OEM exhaust sounds w/ titanium tip
- ART pipes installed = SLOW CAR!!!
- Where is the EVAP box heat shield for my muffler?
- Trouble Installing New Header
- G37 Axle Back on G35?
- Need help! Engine idel/stall after dropping in K&N filter
- Exhaust: Shop smart instead of following the crowd
- Momentum cat delete y-pipe question
- Would an exhaust mod fail the california smog test
- Exoticspeed R2 Titan Catback exhaust
- Exhaust Help!
- How do I add a little growl to an 07 Sedan?
- Apexi N1 Muffler drone?
- recommend Test Pipe or HFC for my particular exhaust setup
- Nissan 370Z / Infiniti G37 2008-2010 3.7L V6 VQ37VHR Stainless Steel Y Pipe
- MD art pipes vs berk/FI hfc's
- Magnaflow X pipe Question...Please help
- Drop in K&N filter w/ Ztube
- Manzo exhaust
- need advice from drivers with exhaust
- Fast intentions hfc vs hks cat back
- Blox 5/16th Spacer- BXIM-40201
- Need help on my o2 sensor for my 2008 g35 sedan
- HFC with replica HKS exhaust and headers
- Stillen gen 3 long tube intake + Stillen gen 2 exhaust?
- Catback and Plenum Spacer
- Getting New Custom Exhaust - Opinions?
- MAF rubbing against engine bay with stillen intake
- Anyone have helix test pipes? Need some input
- Engine cover protect CAI from heat soak?
- help kinetex HFC!!!
- How would you design your straight pipe TP Back
- Help on choosing intake!!
- REVup airbox & Ztube
- Fujita Cold Air Intake (Feedback)
- building an exhaust.
- Resonator delete
- Stillen intake thoughts
- Test pipes
- Moving from Berk HFCs to ART V2!
- MREV2 for non-rev-up
- MD Plenum Question
- oil in intake and coil packs? help
- RS Type N1 Exhaust
- How bad do the Motordyne ART Pipes smell?
- Help locating Rev-up airbox
- megan oe-rs
- ART V2s to FI RHFCs?
- buying a used exhaust?
- exotic speed exhaust
- Getting aftermarket headers and a high performance catback exhaust system....
- Invidia gemini
- 16,18,20 gauge for g35 exhaust?
- 1st Gen Sedan: MD XYZ pipe w/ Megan OE-RS VS Stillen Exhaust
