View Full Version : Intake & Exhaust
- Next step in exhaust system??
- Exhaust
- Exhaust inquiry
- Kinetix VS Stock Manifold W/ 5/16 Spacer Dyno Comparsion
- Kinetix VQ35DE V+ Plenum vs Motordyne Copper Iso Thermal plenum spacer
- Advice on Muffler/Exhaust Situation
- muffler delete
- Legit Has High Power Exhaust?
- TDX2 Fitment Issue
- Muffler Options
- Muffler delete with X pipe
- Oliver Enterprises Exhaust Vents
- Spent a little $$$
- P1273 after Mods
- 2008 G35x Top Speed exhaust and next mod help
- 350z Exhaust on G35 Coupe?
- P0507 High idle help
- Nvidia Gemini exhaust power gains?
- 05 G35X Catalytic Converter Question
- Nismo S-Tune Dilemma
- Any opinions on Ark Resonated High Flow Cats?
- Hello,
- Headers cracked, need replacement suggestions!
- conflicting information on fitting a tomei expreme ti on g35 coupe
- My new setup: Exoticspeed R1-T GT + Circuit Werks Resonated Y-Pipe
- Use a single HFC after Y-pipe
- Need 4 cats- time for a new car?
- Does anybody know the exhaust valve diameter, opening point, duration and centerline?
- Invidia N1 on a G35 ??
- Just z tube for rev up engine?
- Stock intake silencer removed
- Cold air intake
- Bosal resonator ?
- Building my own Fast Intentions exhaust? Opinions pls
- Do the auto & MT have the exact same exhaust? (Coupe)
- Question for NYC members
- G35 coupe 2004 spec D exhaust advice
- Anybody tried the AFE Takeda Stage 2 Dry Air Intake?
- Is it best to keep your whole exhaust set up the same diameter?
- Has anybody tried JUST a Tomei Y-Pipe?
- How much does Stillen True Dual weigh?
- Maximizer Exhaust System anyone running
- HR Y-pipe Vibration
- Need Help ...
- Blox Racing Spacer
- Custom exhaust suggestions
- Invidia Gemini/FI RHFC
- LMT 4 " intake pipe
- N1 style exhaust/y pipe resonated or straight
- Looking for Exhaust System / ebay?
- Which exhaust is louder
- FI Res Test Pipes vs Kinetix HFC
- HFC Diameter vs volume question
- Another HFC thread...
- Takeda Intake TR-3001B
- has anyone done a resonator delete with a magnaflow 14816 or 14815 muffler
- crossover exhuast parts
- HKS Replica exhaust
- Exhaust manifold-cat. Studs or bolts?
- 75mm throttle body PCV valve and new Z tube
- Exhaust (No Smog/inspection concerns)
- A/F,HO2, and O2 Sensors?
- Diameter of Intake
- Need some input on my exhaust
- First post from first time g35 owner. 02sensor questions
- HELP with stock exhaust rattle
- Which Y-Pipe Is This?
- Kinetix HFC & Invidia Gemini Combo
- Exhaust plan
- Tanabe/Invidia guys; help with drone!
- Cold air intake HELP
- Motordyne Long Tube Headers
- Upper Intake Manifold plenum worth it?
- 2008 350z Vs G35 Y-Pipe
- SES P0430 but the car drives fine.
- Got a bad cat, what direction should I go?
- Broken exhaust manifold heat shield bolts
- Which exhaust systems get the highest HP/TQ increase?
- NAPA gold air filter color
- Cheap reliable way to ship exhaust?
- Does the Injen Dual Exhuast fit the G35 2007?
- P1283 code
- Buzzing/rattling after installing Art Pipes
- button
- Best Air Intake System for my 04 G?
- '07 G35 Sedan, HFC or resonator delete
- Cheap Exhaust Tips?
- Y-Pipe 2007 35x AWD
- Motordyne ART Pipes, XYZ Pipe with TopSpeed Catback(HKS Replica)
- Issues after Injen CAI Install
- muffler
- exhaust question
- Loudest exhaust for G35x
- Drive ability question.
- catalytic converter questons
- What are you guys running ?
- Please help, broke oem Z-tube
- Intake Question
- Would this exhaust hanger fit the G35?
- Muffler Delete
