PDA
View Full Version : Intake & Exhaust
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83
  1. throttle body: Coolant Bypass mod
  2. Need Opinions?
  3. HFC's I need a push!!!!!
  4. SES light with FI HFC's???
  5. The Equivalent?
  6. Nismo exhaust + hfc = rasp?
  7. Need a lil intake HELP
  8. Intake filter for 08 G35 Sedan question
  9. Nismo CAI to Short Ram Possible???
  10. kinetix v+/ MD5/16 spacer combo ..
  11. Nismo Extension pipe..
  12. Injen cold air intake or short ram z-tube?
  13. Added Fast Intentions HFCs....
  14. What plenum should i go with?
  15. Any real HP or torque increase from K&N drop-in filter?
  16. Warranty with N/A Mods
  17. Reducing Drone
  18. P1283 still on with nonfoulers
  19. HFC's install
  20. Kinetix HFC install
  21. Is there a fast intentions knock-off??
  22. HKS Hi Power and Motordyne 5/16 spacer
  23. Greddy Evo2 or Nismo exhaust?
  24. has anyone dynoed the blox spacer?
  25. Please ID and Suggest...
  26. Will It fit?
  27. k&n filter
  28. UR Crank Pulley= no audio system?
  29. Installed MD 5/16" copper iso - impressions.
  30. poop charger question
  31. Experimenting with my exhaust....
  32. Is this a custom intake or what? ive never seen it before helpp
  33. Which N1 exhaust is the best?
  34. Next mod...
  35. Cold Air Intakes
  36. Single out 3 inch stainless exhaust
  37. GOOD NEWS::FI Carbon Fiber Exhaust::G35 Coupe::
  38. new gasket for headers?
  39. Fujita intake problems??
  40. is an ecu flash nessecary if you have intake + spacer?
  41. top speed pro n1 exhaust
  42. 06 g35x Borla exhaust, Labree Hfc.
  43. exhaust/y pipe diameter question
  44. OBX y pipe
  45. Removing Muffler
  46. Need Advice, Centre Muffler Delete
  47. Will Injen CAI/SES 1986c exhaust for 350z fit G35?
  48. question
  49. R2c cai?
  50. Wideband sensor
  51. January 1st 2009 HFC'S will be Illegal to sell in California!
  52. [Need Help] Buying Exhaust/Intake
  53. what are good mufflers to use on a custom exhaust?
  54. should i trade my stillen y pipe for an 08hr y pipe?
  55. anyone ported the stock intake manifold.
  56. Wee Little Exhaust Vid.
  57. what other brands make crank pulley other than UR?
  58. what brand used headers should i go with?
  59. HKS Sport Exhaust hp gain?
  60. List of single exit exhausts?
  61. Damaged or Not?
  62. TOMEI Announces EXPREME VQ35DE Exhaust Manifold Version 2
  63. What type of exhaust sounds good on first gen G35?
  64. Blown Stillen HFC
  65. just installed injen cai. question.
  66. Anyone familiar with these guys - Plenum Spacer
  67. Just A Quick Q About Exhaust's ?? Plz Help
  68. Zerd long tube headers
  69. JVT headers??
  70. APEXi NEO INSTALL?
  71. FI Exhaust
  72. Rev-Up airbox on a VQ35DE - special note
  73. Exhaust Diameter
  74. Exhaust question
  75. CAI to Short Ram Intake - ECU Reset Needed?
  76. Fast Intentions Exhaust sitting too low??
  77. Just ordered my Fast Intentions Exhaust and TP's
  78. Intense power res test pipes
  79. any ideas how to make the sound a bit quietly???.
  80. should i remove the heatshield if i install HFC
  81. difference between the revised and the pld version of kinetix HFC
  82. Should I be concerned about crack in catalytic converter?
  83. Quiet exhaust?
  84. THE megan racing v2 resonated test pipe thread....
  85. exhaust to get..
  86. Dynoed Stillen Gen 2 TD
  87. installing coupe mid-pipe
  88. Which exhaust for 2009 G37xS sedan
  89. who all have the UR lightweight pulleys
  90. pop charger heatshield
  91. Plenum Spacer
  92. 03 sedan stillen exhaust ?
  93. Z-Tube?
  94. Stainless vs aluminized exhaust?
  95. Intake question from newbie???
  96. Exhaust Shipping Damage - What's acceptable?
  97. Independent Dyno Testers Needed!
  98. 2008 g35 sedan with borla exhaust
  99. where can i buy burnt tips?
  100. NEW Motordyne Exhaust, Titanium and Dual Setups!
