- aux cord
- Help
- light weight flywheel
- Decal
- Thoughts on Side Skirt Splitter??
- We Need a Z/G East CoaSt
- Did I get screwed? 05' Coupe 6MT NON-REVUP???
- Slip,vdc,brake light on
- What is this part?
- Clutch is sticking in my 04' G35 coupe
- dyno tuner near STL MO
- g35 → 10 years now
- Urgent Please help!
- Berks or Fast Intentions Resonated HFC
- Just purchased a new G
- OEM front bumper question
- Cooling fan issue loud and
- Have you seen this grill??
- Anyone selling their rear stock springs and struts?
- Rohana 19" Rims
- Rear end clunking/poping noise
- Is the motordyne tdx2 louder than a muffler deleted stock exhaust?
- Paid $770CAD for Wheel bearing + labor, front inner tie rod + Labor, wheel allignment
- 05 5at manual mode questions
- Engine Noise(Video Attached)
- tien tie rods grind bump stop?
- Ac/stereo problem
- HELP Clutch Issue
- No trunk button on the 2004 G35?
- 2003 coupe Trunk suggestions
- Can someone help me out?
- Looking for your opinions -~*'`
- Factory jack sucks
- g35 coupe 10.5j +22 offstet set
- Cheapest place for pair of 2004 G35 Window Motor Replacements?
- Passenger rear sagging?!
- Need help
- G35 for Postmates Driving
- Help with Oxygen connector
- Gas door will not close
- Where to get G35 front sport bumper lip?
- Injen Air Intake
- Picture of OEM Wipers?
- new to inifiti, few problems . help me pls
- Purchasing an O2 Sensor
- What exhaust is this and should i get it?
- Thoughts on these corvette rims?!?
- 2007 G35 Sports package Coupe, which rotors to get?
- Used Wd40 to remove plastidip off rims.. they disolved and FUSED to the rims?????
- Found something interesting in the manual case.
- Smog ?
- Speakers not working but radio is no
- Plenum Spacer 5at 05 power loss
- Please help!!
- Exhaust Y pipe
- Volk GTS Rim Repair Question
- Coolant/Sweet Smell through vents
- Lower airbox/Resonator necessary?
- 2005 G35 waterlogged ballast!
- Lsd Question
- Need advice on my mod list
- Died, slip+vdc lights won't start new owner please help
- N1 lip install?
- GTR Shifter on G35
- I finally got her!!
- Thinking of swapping my 06 6MT Coupe for a 370Z
- Little Help With a Couple Issues
- Slap stick shift
- procharger help
- Thoughts on these coilovers? (Car Noob)
- What causes a battery to constantly die?
- What to expect from high mileage g35?
- Overheating !!!!!!!
- Buy salvage car to swap parts?
- Mods before engine swap
- The Search Has Ended
- Help with P0340 code
- Hi guys, its time to change my clutch. Which one do I get?
- Warranty for a G35 Coupe after Elite Warranty expired
- are bolt ons worth it?
- A/T check light flashes 16 times! HELP!
- Clutch Slave Cylinder
- VQ turn off while driving HELP
- g35
- Hesitation then dash lights...
- random misfire/car sputtering at idle after oil change and o ring replacement
- Should or shouldn't I?
- oil catch can
- G35 rear accident HELP
- 2007 G35 Coupe Base _ Brake upgrade?
- Window motor giving me a hard time
- Another One! 04 vs 05+
- O2 sensors not ready p0057
- How many Athen Blue G35 coupes were made?(2006)
- Hot start, rough running
- Front Bumper
- Legality of my G35's modded exhaust
- Looking for 2004 g35 coupe standard shift knob oem
- Rear differential Swap
- ISIS(or ISR) single exit
