- Color Mod
- angel eyes candidate
- Replacing Headlight Blinker Lens
- Angel eyes seem too small for the housing!
- Remove LEDs in Taillight?
- residue build up on headlights 04
- Angel Lights for a 04 Coupe
- Cheap projector headlights
- What is the OE color temperature for 03 G35?
- 06 Projectors Installation
- led fog lights for 07 coupe
- Help with Headlights
- Daytime Running Lights Kit ????????
- Is there a 05 sedan projector kit available or anyone available that can do one?
- hid bulb finally blew after 4 years
- Recommend a 2003 G35 Headlamp Upgrade
- color matching report - silverstars
- 15" CCFL's for clearance strip retrofit?
- Some pics of my headlights painted.....
- colors are off...what to do???
- Philips X-treme power
- Philips D2S Comparison: 85122+ (OEM) vs. 85122cm (Colour Match)
- Clearance lamps - LED swap
- Want headlight housings blacked out (CASKYLINE)
- Question on D2S bulb.
- fog lights
- Changing rear lense bulbs
- Changed Front Blinkers to LED..Blows Fuse..HELP
- 6000k HID D2S Bulbs for 2006 Projectors "56k Ummm No"
- Piaa Cobalt HID Bulbs
- Pulling apart headlamp this weekend to clean condensation
- Mtec 6000k D2C bulbs comparison
- Headlight Recall 06 Coupe
- Headlights?
- LED for Side Corners
- I need input on these LEDS.
- reverse light removal on 03 sedans
- Door Lights
- other 6000k brand bulbs
- 1 zenon not working
- 04 taillights question
- bluebats overlays
- Bottom Tab Broken on 06 Headlight - WWYD?
- Ebay Headlight Housings
- 06 HIDs
- 1 headlight not working
- Help - 03 Sedan Spoiler LED removal
- 06 Foglight Question
- LED bulbs for corners?
- Question about changing my headlight bulbs!
- Once and for all....headlight help!
- LED door handle glow
- LED Problem/Question, Dome Lights
- G35 Coupe - 2007 Headlights on 2005
- 06+ Headlight "Peanut Bulb"
- can you pop out the bulbs in the back seats?
- HELP! 06 projector upgrade
- Headlight bulbs
- foglights for an 06 coupe quick question
- Who makes custom headlights here?
- Headlight Harness Clips
- HID Headlight QUESTION
- People with kenstyle front..help
- '06 Projector INSTALL HELP!
- Replacing foglights and others
- Hello do you have or kno where to find these current products??
- HID 3000k Conv kit for Fogs
- Simple bulb replacement G coupe Tails
- 06 US headlights work in 03 Can G?
- Clearence strip matching
- superbrightleds!!!
- Removing Tailights
- HELP!? Headlight bulb change
- Dealer said changing stock bulbs will blow fuse?
- is this d2s bulb reliable?
- Help! Procedure Needed!!!
- 03 Sedan, replacing center stop light bulb
- 06 headlight problem
- who has clear corners
- '06/'07 Projection Headlight Upgrade!
- Clock Light Replacement - Guide
- Fog lights went out
- H.I.D's.... Looking for brighter than stock (hi lo and fog)
- just installed 06 projectors, need some help
- foggy headlights
- I need 3 types of bulbs...
- Hella bulbs?
- GE D2S bulbs from Retro-Solutions
- 03 sedan headlight IGNITOR-retrofit? :)
- CCFL clearance strip
- What color bulbs in your clear corner lights?
- Phillips 85122+ D2S bulbs 5000k?
- Anyone changed dash / instrument lights?
- 06 headlamps custom trim,lense swap and more!!!
- Stealth bulbs for clear corners - review and pics
- price of 06 headlights
- 06 bulb replacement
- 6000K HID fogs brighter than my 4200K OEM bulbs
- Headlight recall, a difference?
- 85122cm D2S bulbs
