PDA
View Full Version : General Tech Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24
  1. How long has your G's clutch lasted
  2. Rain water in tank...help
  3. Battery Drains Quickly
  4. My g35 is driving me mad as welll as the mechanics woking on it.yur feedback please.
  5. AC line damaged...
  6. Weird Battery Problem - *Video*
  7. REV light stays on
  8. Problem With Power Window
  9. Tail lamp Problem
  10. Oil Breather?!
  11. need help
  12. Car shut down while driving
  13. Car "clicks" when turning on, but doesnt start. Help!
  14. Temperature gauage stopped working.
  15. Gearshift issue
  16. Replacement bolts for undertray
  17. Need help with may analog clock
  18. Help: Door Lock Actuator Replacement
  19. Battery replacement? Help!
  20. Tighter Steering
  21. is it the motor?
  22. Car shut down while driving and won't start
  23. 2006 G35 Possible Battery Going Dead?
  24. P1273 SES Code Help
  25. Trouble Starting, VDC OFF and SLIP lights won't turn off
  26. G died...but not really?
  27. Clunking Noise From Right Rear
  28. Problem with slip, vdc off, and brake lights on dash
  29. Car Running Rough at Idle, SES on, help!
  30. plz help i be your best friend
  31. Life on Tein Flex Coilovers?
  32. Alarm and door lock questions
  33. Low fuel warning sound?
  34. remote door lock trouble
  35. Air Conditioner Problem
  36. Clutch issue
  37. 06 G35 sedan w Elite Extended warranty - power seat issue
  38. YAYY Changed Spark Plugs 100k got a leak! Help!
  39. X2 Performance chip
  40. Engine Knocking......
  41. Need help with tach and water gauge
  42. Air filter for cabin.
  43. '04 G35 Coupe conks out and shuts off as soon as i start it...
  44. exhaust advice please???
  45. Which Grounding Wire am I Missing for GG 10-wire?
  46. **problems with my entire front end of car**
  47. battery problem
  48. Headlight turns on and then turns off
  49. Opening Hood Issues
  50. harness problem
  51. Can't Open Hood
  52. Vdc and slip lights on. I searched but mines unique...
  53. Battery/ Electrical problems????
  54. full inspection
  55. Yet another "the shop f****d my car up" thread...
  56. Window/Door Switch or Door Lock Actuator? or BOTH?!?
  57. installing paddle shifters
  58. Deepest and throatiest Aftermarket dual exhaust
  59. Maintenenace, did I miss anything?
  60. Need Some Advice
  61. powertrain warranty
  62. Will replacing a non-touchscreen display with a touchscreen display function ok?
  63. A/C blow hot air and outside temp stuck at -22degrees,
  64. Front Bumper Paint
  65. A/T Shifting Issue
  66. how to program garage door?
  67. Suggestions for transmission and differential fluids
  68. Air/Fuel Ratio Sensor Meter????
  69. Why does my cruise control randomly cut off?
  70. Compass help
  71. Need help! Stuck with drive belt change on 07 g35x!
  72. Cruise control button replacement
  73. Headlight going pink/purple
  74. need help with some light bulbs, oil change....
  75. New 04 G35 Windshield: Dealer or Aftermarket
  76. Radio is draining my battery!
  77. Service/Shop Manual Recommendations
  78. 06 G35 Cooling Fan removal....
  79. Shipping A Car Accross Country
  80. what does this icon (!) indicate..
  81. Car Temp goes up when AC on
  82. Air Bag confusion
  83. All 4 of my o2 sensors are BAD??
  84. Where do I get this A/C line, mine has a hole
  85. Want Warranty & Mods
  86. 04 g35 Trunk wiring harness
  87. 04 G35 Trunk Locked can't get in
  88. Chicago Serivce
  89. metal rattle grinding noise on cold start
  90. Does anyone know how to calibrate a torque wrench?
  91. 2nd dead battery
  92. AC blowing HOT air!
  93. Heat and AC go on and off randomly.
  94. Driver window switch pin configuration
  95. I30 is on it's third alternator in three months. help.
  96. "05 Sedan tech Vs. 06' sedan tech
  97. Leftover wheel parts!
  98. G Involved in a Small Accident - Electrical Question
  99. A/C will not turn off
  100. SLIP when going over 50mph
