PDA
View Full Version : General Tech Questions
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. Electric
  2. 2008 G35x overheating
  3. intake/exhaust Valve not "rotating"
  4. Random low idle?
  5. Pls don't die
  6. Fuel Gauge issue - Desperate
  7. cranks but no start no spark
  8. Need ,help, asap
  9. Keyless entry remote not working on first try
  10. g35 brakes question
  11. Wife left car door open can’t start car
  12. my push button is flashing and goes to on position but wont start what does that mean
  13. Odd Window Issue
  14. Bcm
  15. VDC off and Slip light on
  16. 03 g35 coupe passanger seat stuck forward won't slide back
  17. Am I doing it wrong?
  18. Ground strap, LH (driver) side connected to the head.
  19. G35 coupe cranks but no start.
  20. Drivers side rear tail light
  21. Code P0021
  22. Disable Driver Side Airbag?
  23. P0037, replaced sensor, still throwing code
  24. DIY: Fixing Broken Magnetic Center Console
  25. 05 G35 Coupe Door locks need to charge to work??
  26. Need Info on NATS systems 2003ish
  27. Inquiry: Unnecessary Parts?
  28. G35 coupe shakes when idle
  29. rough idle and power hesitation
  30. Trunk Button on Trunk Lid No Longer Works
  31. Something strange happened to my hood - it shifted
  32. Front wheel hub install
  33. Intermittent runaway idle, please help.
  34. Need Help Finding Part
  35. New owner newbie here. RPM issue.
  36. Another overheating Thread
  37. Looking at a tune for my G35x
  38. Need a new toggle lever.
  39. Best place to buy OEM parts?
  40. Possible plenum leak?
  41. Problem with my car. Please help.
  42. Help with a cruise control issue
  43. Just bought G35, throwing 8 codes
  44. Thunder Bolt Performance Chip
  45. STILL misfiring! Tried everything. PLS HELP!
  46. Multiple Issues. At a loss for words.
  47. Not another rattle thread
  48. Ignition switch is frozen
  49. Power steering pressure sensor (please help.. starting to lose it)
  50. Evap Vent Tube warranty extended to 15yr/150K
  51. *PLZ HELP* Loss of performance/ P0327 NO CEL?!?!
  52. Ignition switch wont lock
  53. Coolant leak ?
  54. AC amplifier?
  55. Bolting differnt sized flanges together.
  56. Need help with AC clutch/bearing PN info
  57. What is Fuel Trim 1/2 vs STFT/LTFT
  58. Diamond Graphite paint code
  59. Aftermarket Fuel pump!
  60. Replace fuel pump or whole assembly?
  61. Valvoline coolant flush
  62. g35 no crank, no electric
  63. 2006 coupe window issue
  64. mile or km?
  65. Problem with Automatic Windows
  66. Engine oil exploded from under the engine
  67. Locked / Seized brakes, and Hard Brake pedal
  68. Alternator and Harness Wiring
  69. Emergency! Need help ASAP!
  70. G35 P1283 Code
  71. New G35 with a few Questions
  72. gas tank capacity
  73. 2006 trunk won't open
  74. Replacing service engine soon cluster bulb?
  75. Getting P2A03 error code
  76. 2004 G35 No Lights No Electronics No Ignition Full Battery
  77. Car acts funny once warm!!
  78. 2003 infiniti g35 coupe temperature goes all the way up with coolant bubbling
  79. 2004 G35 Stuck In Limp-Mode
  80. Y pipes that fit '06 G35x models.
  81. Interchangeable parts
  82. What seal is this for???
  83. which part?
  84. HELP! G35 High end loss of power
  85. 2010 G37x Window mind of its own!
  86. Exhaust install question
  87. 07 g35 revup VQ37HR swap
  88. Please help, trunk won't open
  89. How Long Have Your Aftermarket Parts Lasted?
  90. Need HELP G GUYS !
  91. Radiator Fan Harness Connectors
  92. Squealling Sound Coming Front
  93. Wheel Hop
  94. Fuel Pump Recommendation
  95. Tick/Knocking noise coming from the engine
  96. Vendor review: Beefcake Racing Team - Vortech V3 Kit
  97. Accidentally poured water in pcv valve...
  98. Steering wheel problem
  99. Weird sound from right rear!
  100. FYI Replacement for discontinued small IPDM relays
