PDA
View Full Version : General Tech Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24
  1. How to get power from cigarette adaptor with ignition off?
  2. car problems- vdc, tire pressure and window
  3. Recommendations on lube....
  4. Tips and pointers in driving...
  5. trouble!! help!!!
  6. OBD, data logging, and thermal spacer
  7. Darned impact... do i need a new one?
  8. Problem with AC temperature changing to 60 degrees
  9. gauges like 350z
  10. Key Stuck in Ignition.. help!
  11. Does these front set tire fit?
  12. Is the 350Z windshield the same as my G35 windshield
  13. Auto Heat Issue
  14. Electrical Issue, headdlights, door lock Window
  15. Windows won't roll down and doors won't lock
  16. Car doesnt start sometimes
  17. Help: Rewiring Parking Lights to be on when car is on
  18. Numerous problems...is my BCM bad?
  19. Impact guns and compressors
  20. Need help trying to get more hp without turbos or Supercharged
  21. steering wheel question
  22. e brake question
  23. Need Help with Winshield Wiper (Doesn't spray)
  24. Wiring Loom Diagram
  25. Strange Noise When Braking in Snow
  26. 13 gallons?
  27. All wheel drive G35?
  28. Question about my window problem
  29. an odd question...
  30. Computer is not connecting to the internet????
  31. Will this get too hot?
  32. Engine
  33. Airbag light
  34. I have some squeaks, anyone have the same ones?
  35. Drain Plug Washer
  36. Changing out wheel studs
  37. Unordinary problem
  38. Radio and AC problems
  39. --------30K Service---------
  40. Adjusting Window Tint
  41. Resetting ECU = Better Gas Millage???
  42. Cigarette Lighter
  43. Possible Timing Chain / Transmission Problems 2003 G35 Sedan
  44. Current OEM Oil Filter Part Numbers - ?
  45. Hood damper
  46. Trottle actuator code, g35x 2004
  47. Warranty question on used G35
  48. Whining noise-possibly from trans/ synchros?
  49. Shipping seats??
  50. Engine service light on after sparkplug change???
  51. question on 6mt coupe
  52. ecu wire diagram for 03 coupe
  53. HKS DLI INSTALL?? Anyone have this installed or know how too?
  54. Why hasn't Infiniti incorporated direct-injection into their V6 yet?
  55. uploading pics
  56. 05 coupe oem navigation conversion????
  57. Are You a New Owner - Board Member
  58. Torque Wrench Maintenance?
  59. OEM Battery Weight
  60. :: Question After Installing New Bank 1 O2 Sensors ::
  61. 03 sedan problems starting
  62. What if it's stolen???
  63. Covered Under Warranty?
  64. Tow Hook Thread Size
  65. Louder Horns??
  66. Battery
  67. Battery Keeps Draining
  68. shock
  69. keyless or intellikey
  70. Self-serve garage survey... please read.
  71. I'm Ssssssmokin'!
  72. radiator fans not working (not even with AC)
  73. Fuel Gauge - showing empty but gas tank is full
  74. 80k tune up?
  75. Heater/airconditioning control down!
  76. Weird spring/clunking noise after going from ignition - drive - accelerate
  77. Like an xmas tree.
  78. Top Engine Knock
  79. Car won't start!!! Click noise --> battery?
  80. syphon gas?
  81. Car has no power...
  82. Codes U1000 and P0462
  83. Infiniti Service
  84. deciding best route to go
  85. Automatic trans/vibration//driveline
  86. Brake Light not working?
  87. How exactly does the VDC and SLIP work?
  88. ****AC/HEAT Problem ALWAYS HOT AIR****
  89. heater
  90. ses light on code reads po302
  91. How to Remove OEM spoiler light housing to replace light in spoiler..
  92. heater not working
  93. No heat an im freezing to death..
  94. laser platinum more money than iridium
  95. I jacked my car up in the wrong spot
  96. service manual
  97. Tire pressure light on...but pressure ok
  98. What temp you put when raining?
  99. Changing odometer to kms ???
  100. what is this switch
