View Full Version : General Tech Questions
- How to pull ABS codes?
- Driver seat airbag
- Cat converter
- Car cranks, won't turn over
- Fuel gauge messed up
- G35x stabilizer bar connecting rod (endlink) help!
- master and slave clutch problem
- Bottom clips for airbox
- What to expect on maintence
- tachometer needle problem
- 05' Coupe door switch issues
- Shakey wheel and less torque
- My 2005 G35 coupe keeps ticking ?
- car wont start
- G35driver VINs
- Airbag compatibility question
- The Helpful Tips and Tricks Thread
- WINDOW MOTOR HELP!!! (coupe 07)
- Wanting to tune my car and get gauges
- Car will not go in park
- Car wont star after replacing battery
- Rough start, Service engine soon, slip, and VDC off lights on
- Power Steering Leak
- Help w/ naming wires.
- Fan Stopped Working
- Slow 0-60
- 04 g35 coupe headlight problems
- Which tuner to use
- Window Drop
- Fan wiring
- Help, VDC OFF light, SLIP light, and SERVICE ENGINE SOON light all on
- 07 G35 changed spark plugs and now it wont start
- Best OBD2 Scan Tool for G35?
- New body harness, and shitty aftermarket security system
- Part number????
- alternator question
- shortened exhaust hangers?
- Resonator delete on a '04 Sedan?
- Car shaking past 80MPH and slow rev problem :(
- 2005 Coupe Window Switch Chatter/Whine
- Passenger Seat Air Bag Recall
- Rattle
- Stock AC on Metra Dash kit????
- HVAC problem
- Alternator pulley HELP
- Scan tool
- Someone for the love of God, Help me!
- Driver's Seat....
- Window control module? (auto roll down with remote)
- OEM manufacturer for starter motor?
- Trunk broken
- transmission problems =(
- $250 for a Tune Up? Is this right or a scam?
- Door jamb switches
- Intelligent power distribution module
- should I only use a Nissan radiator cap?
- strange rattle front JWT clutch setup.
- Service Engine Soon light
- Need help with a temperature problem!!
- Need help confirming a spacer
- Spacers with or without studs?
- 2004 g35 frame damage!?!?!
- Car locked up on me question "Alarm''
- Grinding sound from the rear.
- I need helping finding the part driver keyhole escutcheon hooks on to
- Lowered?
- Carbon fiber diffuser
- Audio A/C Control Unit
- Vibration SOUND coming from what seems like front wheels
- Shutter Noise Coming from under the Hood?
- Rear Bearings / Front Bearings
- overheating and stumped, checked everything
- Please help, where can I get this part?
- rev up injectors in DE motor
- I got P2A00 code, advice please
- Advice on a 03 G35 coupe I looked at today with interior light function problems
- Beeping when shut door. help!!
- Help! Car starts but won't stay on
- Low idle when I come to a stop light??
- power seat not functioning correctly
- oil cooler sealer is leaking
- Check Engine Light On or Flashing? Have a code? Find out what the code means
- need help
- Window motor
- Build Date without sticker PLEASE HELP!
- Scissor jack with jack stands
- G35 cranks but wont start
- Tuner shop near Savannah, GA
- 2004 G35 stalling while driving
- Burping works but still overheating
- Roll rusted fenders?
- Window Issue....
- gear shift issue
- "Engine Cont Inj" Fuse keeps blowing, car won't start
- tbs and cam sensor? i really messed up
- Need help finding this part..
- Can really use a quick answer if available!!
- Foot Vents Help...
- A/C not blowing cold?
- Maintenance at 100k miles and above?
