PDA
View Full Version : General Tech Questions
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. Painting to Match
  2. 2004 g35 passenger window not working
  3. Hazzard Flasher
  4. ECM refurbish or replace
  5. Oil Seeping out of spark plug well AFTER replacing valve covers.
  6. Ac clutch barely spinning
  7. new steering wheel?
  8. VDC and slip light on!
  9. New to forum with a few upgrade questions
  10. oil change without removing the skid plate?
  11. Air bags
  12. Headlight problems
  13. Steering rack "seeping," should I use stop leak?
  14. No spark?
  15. Dealer labor rate?
  16. Lost key
  17. 350z suspension w brace
  18. Car Keeps Dying
  19. Cooling System Battle
  20. Bumper question
  21. Antifreeze?
  22. weird timing issues & no power
  23. Leak found?
  24. Missing bolts?
  25. Sunroof Isn’t Level
  26. Power loss
  27. 2004 G35 Sedan 6mt ~ Various Issues; possible bad ecu/bcm, slip & vdc lights on, etc.
  28. 2003 died at idle, restart with long cranking...
  29. E-brake, CEL, SLIP and another light on dash
  30. 2005 g35 heater blowing cold
  31. Ac display not working, SRS light on
  32. G35 won’t start at all
  33. New G35X 05
  34. P0327
  35. how to bypass the nats system
  36. Alternator keeps going bad
  37. 05 G35 Coupe overheating and no cabin heat
  38. My $300 unfixable sedan... -_-
  39. Check engine light blinking
  40. G35 coupe makes rattle noise when cold start and sometimes while driving
  41. Trouble Disconnecting High Pressure AC Line
  42. No keys, Ignition swap issues, HELP
  43. Temperature guage going to Hot
  44. Nothing holding headlight
  45. G35 infiniti 2005
  46. Trunk won't open
  47. Clicking with recirculating AC on
  48. weird metal noise
  49. What is this part and does it need replacing?
  50. 2010 Dodge Journey SXT Jammed Door
  51. Recently replaced Clockspring. Now car won’t start.
  52. Cracking radiators
  53. Exhaust popping
  54. help
  55. My security alarm won’t turn on
  56. Where is the a/c compressor relay?
  57. IPDM Delete
  58. Need help, ignition switch issue
  59. g35 won't start, no click, dash lights turn off when key is turned
  60. Hello,
  61. Need Help Identifying 4 lines
  62. 2004 G35 Sedan A/C Condenser Install Help
  63. Over heating
  64. Please Help, door refuses to lock/unlock
  65. 2004 key fob not working, wont program
  66. Emergency trunk release broken
  67. Lights interior and door
  68. Engine Splash Guard keeps Interior Warm?
  69. anti theft won't let it start
  70. AC unit replacement (Desperate)
  71. Headlights
  72. A/C and Heater both not operational. Blowers are working.
  73. Crazy idle
  74. Unsure Overheat or Normal ....! G35 2008
  75. 03-05 g35
  76. Air bag light - no fault, but keeps recurring?
  77. Weird oil burning issues
  78. Packages...
  79. G35 will NOT accelerate..HELP!
  80. Torque Results Show bad "Rich sensor threshold"
  81. Turkey banged up muffler
  82. VERY odd blinker signal problem
  83. G37 A/C driver/passenger temp issue
  84. Day of reckoning / dealing with my poor decisions!
  85. Timing chain check and adjust?
  86. Clutch acting weird
  87. HELP! Need ECM Model Number explation/breakdown for Compatibility l!
  88. Please help! Ground Fault at CMPS connector, won't start. Also ECM help
  89. Timing chain Tensioner?? How To?
  90. What should I get?
  91. Knock Sensor Harness
  92. Slip VDC Ses light gone, still hesitating.
  93. Cat education?
  94. Abs sensor
  95. Carbon build up and strange idle.
  96. Passenger side switch not working
  97. D.I.Y water pump questions
  98. Airbag Light/Potential Clock Spring Issue
  99. Installed wrong battery reversed posts. Won’t start
  100. RJM Clutch Pedal and New MC Troubleshooting
