View Full Version : General Tech Questions
- oxygen sensors
- Sunroof Problem. Help is appreciated :)
- G 35 rwd one legged
- Hard Transmission Shifting - Read Details, Please
- Car revs being limited to 3500 rpm in 2nd or 3rd gear?
- oil additive
- Need help! Car shut off while driving to work.
- Door switches, horn, headlights, tail lights problem
- 03 Coupe Starting problems
- Startup Issue and CEL (check engine light)
- Slip Light, VDC off light, and Steering wheel not aligned, please help!
- Mrev2??
- power steering help
- Plastic underbody engine shroud
- First trans fluid change at 90k on my 04 a/t
- White steam coming from engine after radiator change and install.
- Slight white smoke and fuel smell from exhaust
- G35 coupe help!
- Coolant level issue
- Help please! Part number needed - Headlight bolt?
- G35 fuse box
- **** need a little help lost all info *****
- IPDM fuse box question.
- Beck/arnley coolant?
- Camshaft Position Sensor Connector
- What would you do?
- SES Light On, Codes Read, Next Step?
- What is the thread size of the 32mm axle nut for our cars?
- Parts Catalog
- Weird Fluttering Noise When Gas is Pressed
- Slip Light, Vdc Off Light, Service Engine Soon Light Off & On
- Won't be driving my G for 2 weeks, will my battery be okay?
- New Battery & Flickering Dash Control Panel
- Trunk latch keeps bending
- weird throttle body reving by itself.
- Slip light help please
- Need help answering this question
- 2003 G35S Sedan passenger door issues
- Time to get the Instrument Cluster repaired
- Different size rear tires made Slip light on?!!
- Cruise control not working
- Battery Dies and VDC is Messed Up
- Dash lights flicker upon start up
- 04 coupe leaking oil
- A quick conundrum
- Tested: Clutch Pedal Heavier than it Should Be. Help!?
- 2006 g35 coupe 6mt won't start up
- Electrical issue.. no backlight in cluster, no A/C or radio
- wet footwell - possible leak sources (2004 G35 Sedan)
- Grumble @idle & low RPM - exhaust leak?
- Exterior light issue please help 04 g35x
- Mad Clicking
- Alignment
- CEL, VDC OFF, SLIP with DTC of 4003?
- Replaced battery and Key FOB battery and car still won't start
- Car went crazy after locking doors after rain!
- Washer Fluid light
- Bad Battery or Bad Alternator?
- Gas fill up weirdness
- 2007 G35 Overheating? Temp Gauge Goes From Normal to High to Normal
- passanger axle replacement
- I will burn this thing...
- G35 Valve covers
- Air conditioning problem
- looking for "rev-up" specific mods dyno results
- G35 coupe trunk problem!
- 03 G35 Sedan ABS, parking brake, slip, VDC off, and battery light on - Won't drive
- Help w/ o2 sensor + code P2A00
- lurchinglurching/studdering/power loss on cold startup
- Please help if you know anything about window regulators
- G35 Coupe TPMS & Brake light problem
- Wierd P1762 code.
- JW how long I can go with....
- Air Conditioner AC System
- I popped a fuse and cannot find it.
- HORRIBLE gas consumption
- Clutch fluid leak maybe?
- Cigarette lighter- not ok for radar detector?
- How can I break into a G35 Coupe?
- Car stalls while drivng HELP
- Where to find amsoil severe gear oil?
- Bent rear "W" crossmember brace... suggestions?
- Passenger door lock actuator
- Y Pipe question
- need a reputable auto repair shop in las vegas
- Car wont start after adjusting my new clutch PLS HELP!
- overheating i dont know what to do!!!!
- VQ35DE Burns 1 Qt per week runs fine
- Help!!
- AT fluid drain and fill at 90k
- 07 sedan A/C pressure switch
- Rattle at Startup
- Touchy AC
- Car burning through coolant fast
- Lift engine with floor jack
- Quick Question on Dealer Tune-Up
- General Question after rebuild with oil and driving
- Car accelerates up to 20 mph and wont reverse. codes P1078 P1084
- Engine Reving while coasting
