- Cruise Control Issue
- Exhaust Question
- 2004 G35 sedan Driver seat problem
- noob needs simple assistance
- Cruise Control turns off with signal light selection
- Fuel sending units
- Loud squealing noises in the cold season.
- 03 New Gauge Cluster Colors?!?!?!
- Service ENG light + Slip+ VDC=???
- Not hitting 60 in 2nd?
- Issue with screetching belt noise.
- G35 cluster gauge problem
- Interesting problem...
- Annoying sound in rear
- The strangest leak..
- will taking out the infiniti symbol live a hole in my grill?
- Lifted on 4 jack stands. Is it safe?
- Telescopic Steering Wheel
- Berks cats or test pipe?
- Fuel gauge broken
- Are 5-114.3 and 5-115 wheels interchangeable?
- Oil Change..regular and synthetic
- radiator fan Relays for $457???
- New Wiper blades. 06 coupe
- 04 G35 sedan rear window only goes down not up???
- does anyone know what causes this noise..?
- Need help please!!!
- IPDM Fan Radiator relays Location??
- Blower fan for climate ctrl not spinning - intermittent
- Help cant get car to start
- what tool is used to remove this ?
- ticking noise
- cluster panel help =(
- Brakes Plus Fluid Change
- Intermittent Rattle/Clank coming from engine bay
- Questions about shop and Aftermarket part.
- Hella triple air horn install help needed g35 sedan
- Undercarriage Ideas
- Type of grease to buy?
- False Lights On Gauge Cluster HELP!!
- o2 heater problems please help
- Moonroof problem g35 (closes too much)
- 04 G35 stuck in park
- vendor question
- 03 sedan front passenger side window
- Airbag Diagnostic Code
- Change color of odometer?
- reprogramming a key fob
- keyhole cover broken off!
- driver's window opening door
- car wont turn over
- wont let me go pass 2.500 rpm's .
- Drivers Window
- speaker harness?
- Fuel filter??
- Check engine light on - code is PO 455
- Air bag light flashing???
- G35 sedan winter tire question
- clutch pedal wont come back up?
- PCV Filter Location
- Can someone tell me what parts are missing
- Strange Buzzing toward rear of engine!!!!
- Horn Doesn't Work
- Checking Milage
- DIY security and theft deterrents
- Clicking/chatter from rear during load
- 06 Projector conversion (HID won't work)
- Knocking sound from engine at 3.5rpm.
- ECM Re-Program for US Spec G35 in UAE
- Ac keeps blowing fuse
- need help. how to repair a split wire?
- need 2 part numbers pleeeease
- Having trouble with bluethooth communication with new phone on '07 G35 sedan
- Having rouble with bluethooth communication with new phone on '07 G35 sedan
- transmission slipping/ AT 03 Sedan 100K
- VDC issue while cornering
- Car wont start for several minutes Please Help
- power window problem
- Multiple Cylinder Missfire
- Urgen help, gas cap lid not open
- windows roll down by themselves?
- 04 g35 over heat
- Passenger Door HELP (wiring)
- fuel level sensor?
- Parking Sensor or Parking Distance Control on G?
- US 06 coupe headlight
- Why does my idle drop to zero after my car warms up?
- Where to get used 2003 g35 6mt w/navi coupe ecu?
- Passenger Window Problem
- Squeaking noise coming from driver's tire
- Rear Driving lights and tag light out, Help!!!
- modified exhaust...
- Clicker not working, inside locks not working.
- Driver Side Window and Lock Issue
- Front Windows lower when exit car!
- Dash lights by clock blinking?
- HELP PLEASE, a/c blows hot air , radio works fine????
- weird sound
- Engine splash shield
- which fuse is for cruise control ? ('07 G35 Coupe)
