PDA
View Full Version : General Tech Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24
  1. AWD Tie Rod End?
  2. 06 coupe passenger window issue
  3. 06 Revup questions...
  4. Problem with windows motor?
  5. help problem with AT CHECK?+TPS SENSOR?+SPEEDOMETER?+SIGNAL LIGHTS? AT COLD START?
  6. 2004 G Coupe Radio/Speaker/BCM issues
  7. 2008 g35 - rpm dips!!! Help!!
  8. NEED HELP! 2007 G35 - The 15A Fuses for blower motor keep blowing
  9. 2005 G35 Car won't start please help
  10. some general maintenance questions.
  11. Vdc and slip light always on and red brake
  12. 2007 G35 - The 15A Fuses for blower motor keep blowing
  13. need to push gas for car to stay on when i turn the key
  14. Rattling noise when hitting bumps
  15. RPMs acting funny after cleaning maf sensor and throttle body
  16. overheatin
  17. Gas Gauge Needle on Wrong Side of Pin
  18. A/C kicks on automaticlly & dash controls wont work just steering wheel controls will
  19. A/C kicks on automaticlly & dash controls wont work just steering wheel controls will
  20. Fx35 and G35 both 2004 BIG QUESTION
  21. axle sensor?
  22. ?michigan auto shop?
  23. dont buy from these guys!!!
  24. G35 help Please
  25. DLC power fuse
  26. RPM fluctuation after plenum spacer install -need help asap-
  27. how to semi permanent lift car??
  28. light metal scrape sound. Help please!
  29. orisis tune?
  30. I really need tire help...
  31. Question about repairing a 2008 G37
  32. M/T & Diff Oil Change...which oil?!?
  33. Conversion drive by wire to cable throttle
  34. Help 04 6mt coupe overheating
  35. OBD II test??
  36. check engine light!!!1
  37. g35 paddle shifter
  38. Exterior a pillar
  39. 06 g35 wont rev past 2k rpm
  40. Humming noise ..
  41. suspension question
  42. Drivetrain chatter
  43. warm start stall
  44. Winshield wipers jumping ???
  45. car jack?
  46. Would this be considered normal?
  47. air intake silencer
  48. looking into a g35. got ???s
  49. Spark Plugs at 60K
  50. color of new pennzoil syn blend oil
  51. Help check engine light on P1706 PNP switch-no signal change
  52. Water sound from dash
  53. rear light needs to be changed and I need help
  54. water problems
  55. Sun Roof wont close on its own...
  56. Car wont start when turning key.
  57. Amp Draw range when car is off?
  58. PCV socket size.??
  59. 2004 g35 coupe 6mt gear oil leaks, need suggestions!!!
  60. 225/45/18s? or 235/45/18s?
  61. center console done?
  62. HELP!!! Engine light in NOVA
  63. Grinding or rubbing issue between 15-30mph
  64. Do bigger oil pans read the same reading on dipstick?
  65. Car is not going into gear help!!!!
  66. Cruise Control Button
  67. Need help or ideas on relocating positive batt. Wire
  68. White smoke from exhaust
  69. 2004 G35X Sedan Blowing Fuses
  70. Battery drain - I guess it's my turn! :/
  71. stillen front strut brace
  72. Window Problem
  73. need help
  74. NO heat under 2.5k idle
  75. Should i upgrade to an 04-06 g35?
  76. Whts the diff. b/w comp. sc. &engg.(cse) and Info. tech.(IT). I want general ans dat
  77. 2007 coupe o2 wiring diagram
  78. will the intelligent key start car in trunk
  79. '06 G35 Sedan Heater Problem
  80. VDC OFF and alignment issues
  81. '03 G35 sedan
  82. Random no start/ blank gear indicator
  83. Intermittent ignition problem
  84. Two weird problems with the car... HELP!
  85. Diagnosing an issue....need help.
  86. prox key/ transponder DEAD question
  87. What are these for and what do they do?
  88. Cold weather start-up!
  89. What is alternative for me to cast vote in this general elections?
  90. REV light
  91. Manually raise/lower power windows
  92. Dash lights on
  93. Questions about new rims and tires.
  94. pulley or bearing squealing
  95. Window Washer
  96. Fixing an Alternator
  97. Turn Signal Issue
  98. 1997 infiniti I30
  99. Oil Change Question
  100. Upper oil pan
