PDA
View Full Version : General Tech Questions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24
  1. 2004 coupe GPS problem
  2. Car starts, then shuts off...
  3. coolant cap
  4. G35 smoke coming out of my engine
  5. 06' stock coupe, auto, athens blue
  6. My key fob works intermittently....!!!!
  7. Window Motor Probs
  8. Help!?!?!?!?!?
  9. Driver Seat Airbag Problem,( need help)
  10. Multi point inspection and warentee ?
  11. Tires for 2006 G35 6MT
  12. Want to upgrade my OEM Horn. Any recommendation?
  13. Tachometer Jumps, erratic
  14. Steering wheel shakes
  15. Key doesn't unlock doors/battery draining
  16. security system going off for no reason.
  17. The VDC,Slip, and Brake indicator lights!
  18. Alignment specs
  19. Brake Light Replacement
  20. Nissan FAST
  21. Help, bumpy ride
  22. Anyone have a wire tuck DIY?
  23. Sunroof
  24. brake upgrade 06 dual piston
  25. Regrease n Clean Axle Twice n Click comes right back
  26. Hello! Lowering Question
  27. So when our brakes get bad our traction control goes off???
  28. Can anyone recomend an Infiniti dealer that can sell me an OEM part
  29. Is my car ok?
  30. Key not working
  31. RAS light and SLIP light
  32. AC won't stay cold
  33. Cooling Question
  34. Opinions on yellow coolant
  35. nismo radiator cap
  36. Best Anti-theft protection? Ravelco
  37. ground wire points for trans and ecu?
  38. multiple error codes
  39. g35 factory jack unique?
  40. shaky steering wheel
  41. Droning noise when driving...
  42. my civic failed smog...any suggestions?
  43. Airbag replacement?
  44. Error codes need some help
  45. A/C and Audio went dead
  46. Fx wheels on a g?
  47. 350z cover on a g35?
  48. Complete DIY's on starting, charging, engines, trannys, etc.
  49. Valve Chatter or similar sound from engine
  50. Sunroof
  51. help Idler pulley broke!!!!!
  52. AC turns off at high speed
  53. Wide or Narrow Band O2 sensors
  54. Key will not turn
  55. Is Cyberdefender good? PC Tools?
  56. Clicking noise when braking
  57. Steering angle sensor
  58. Computer diagnostic ('04 sedan)
  59. Removing gas from the 07 model
  60. AC is only cool while moving.
  61. Trying to remove Glue
  62. Inaccurate Fuel Reading
  63. Car dies @ higher speeds
  64. Cold air from AC only works at 60 Degrees
  65. 350z engine swap into a G35? feedback ASAP
  66. Strange battery/headlight/interior light problem
  67. which strut bar is recommended?
  68. A/C Died in Palm Desert!!!
  69. Door Lock Broken??
  70. I-Key issue
  71. Help! Rev light!!
  72. Engine Bay Hose Sizes!
  73. Car smells hot
  74. I Want to change the Spark Plugs
  75. Oil Pressure Readings
  76. FML NEED HELP with my trunk!!!
  77. 90k service: what can i skip?
  78. Belt Issue - Any ideas as to what is causing this?
  79. Has anyone upgraded their horn?
  80. Interior dome light
  81. cant open my trunk
  82. A/C not cold enough?
  83. Starting/ charging problem/questions???
  84. DIY for polished plenum
  85. Help!!a big crack on the left flex pipe
  86. List any good or bad interactions with auto part websites
  87. repair & parts tech manuals???
  88. It seems a bit limp
  89. my car seems to get weak when im holding down both power window buttons
  90. Changed battery...now won't start :(
  91. Tuning
  92. rims for g35x
  93. how much nitrous
  94. undercarraige stuck bolt
  95. passenger side window wont go down plz helpp!!!!!!!!
  96. Seat Recline Doesn't Work
  97. a little help
  98. do g35's have auto locking door locks??
  99. Rear view camera
  100. Navigation problem
