- Steering Lock
- Andysautosports?
- VCD and SLIP Lights come on
- Grom Unit
- M2 Exhaust gaskets
- Sub Frame Question
- Noob with turbo g35
- Powersteering even worse
- Engine management light issue
- Window Regulator install
- "slip" light and and traction control light
- Power Seat Motor
- G35 Key and Remote
- G35X Burning Oil
- Front Diff + Transfer Case Fluid Change
- Fuel Filter
- HVAC fan made noise, stopped blowing
- Help..CEL code P0057 HO2S heater control circuit low(bank2 sensor2)
- fuel pump change now cluster problem
- Need help.. Power Steering
- Scissor lift recommendations?
- Please help!! I didn something bad to my engine!
- fuel gauge problem
- DIY: Fuel Door Lock Actuator REPAIR
- Overheating help.... 03 coupe... Answers?
- P0300 question
- 2005 G35 Sedan Blower Not Running
- basic mod order 03 coupe
- tranny grinding upon engine braking 6MT help!
- forgot pin code
- Pin code forgot
- Disabling DRL on 04 Coupe
- troubleshooting.?
- Seat Belt Bolt Question
- Damn CEL! HELP!
- Suspension lubrication
- Check engine light code
- System Low End Sensors
- driver window works in reverse( I have not drank too much)
- Battery vs spark plug vs window problems
- Very choppy tires
- planing to buy a long tube headers for my sedan
- Possible resetting of the CC sans stereo
- "zip" sound when going slow in 1st gear
- Ecu problem
- Weird Scrape Sound?
- new engine
- Gas Gauge Issues
- replacing AC line
- Driver Side Door Lock
- detonation
- Air Duct Hose has hole?
- Help please car wont start!!
- Help!!!
- (pretty) Simple tire compatibility question
- 2003 G35 Coupe AC compressor failure
- Acceleration and Backfire Problem
- Drivers Seat Fix
- Start-Up Issue
- Reverse lights out and your car wont start. (answer inside)
- 05 G35 Sedan Headlight issue.
- Quick Oil Question...Oil Gurus Please Chime In
- DVD NAV spinning more often since update
- 06 Coupe Overheating
- There is a ghost in my car
- A/C line damaged?
- compass issue
- 2004 G35x front growling/grinding noise at idle
- Steering got stiff in a specific range
- TPS in 05 G35x
- Front amber bulb on headlight not working?
- New to me pre-owned - codes MUST be related!
- Window Keyless Down Issue
- 03 coupe looking for tramsmission ECU
- Driver seat one button issue
- service bulletins éÉ
- Dash lit up like a xmass tree!!! HELP!!!
- Help :(
- 06 coupe dash issues (tach,vdc,slip,rev)
- Exhaust system dilema
- Key FOB battery replacement
- Power window fail??
- Another rattling thread...
- Air Bag light blinking nonstop! Help
- fuel solution
- SES Light is on - hesitation when starting
- 06 g35x exhaust pipe id
- AT cont fuse keeps blowing
- Fuse out? Interior Dome lights 2006 G35 Sedan
- Will 2007 g35x bc coilovers fit 2005 g35x?
- Fender Rolling?
- Where to make cuts on JDM battery cover to fit
- where does this go???????
- HOW DO You Bleed an engine?
- tailight blown
- Window rolled down by remote, won't go back up now.
- Having keyless entry issuess, need assistance
- Swampy ac smell
- 03 g35 coupe has fuel but the low fuel light is on.
- Bank 2 sensor 1 cats located?
