View Full Version : General Tech Questions
- Main Cooling fan Issues
- How to access blower motor relay behind fuse box?
- Driver side window issue
- is this normal?
- What exhaust do I have?
- Does Nissan dealerships do Infiniti keyfobs?
- Rebuild vs used transmission?
- Windows go down, Alarm goes off HELP!!!
- 04 coupe 6spd WONT START HELP!
- G35 Coupe Power Steering issue -- Dealer says lower U-Joint, What do you think?.
- Bad vibration
- 2008 g35s Sedan; which warning lights are suppose to stay on..
- Help me figure out my intermittent AC Issue. Will work at idle.
- 03 coupe window doesnt go all the way down
- ECU throwing 6 codes - P1148, 1168, 0037, 0057, 1031, 1051
- G35 cooling system weakpoints?
- My car doesn't have heat until I put it on 90?
- What plug is this by the brake pedal?
- Steering wheel won't go down.
- Please help! What is this sound
- So my mom drives a 2010 FX35, I drive an 05 X
- 04 g35 coupe engine harness help
- 2005 AT making exhaust grind
- code p2135? car went into safe mode 3 times this month..
- Need help! 2008 G35x Power Window issue
- What make my car wrong speed?
- Loose brake caliper
- G35 Coupe Seat Does Not Move Forward To Get Into Rear Seats
- SRS Airbag Light Solid - HELP
- Nissan Dealer Question
- Ambient Temperature Sensor Replacement
- 05 G35 Passanger Window Stuck
- front end damage
- What size bolts for splash guard?
- Want your opinions about possibly installing a Apex AFC Neo
- Christmas Tree dash /// different from others
- Help..2004 g35x..codes p0455 and p0430
- NEED HELP troubleshooting! My steering wheel locked up on highway !
- VDC, SLIP and ABS, and no brake lights!!
- Engine bay question
- Adjusting side mirrors?
- Stillen Intake + Z Tube Kit HELP!
- Wont shift into park
- oil drain stripped
- Car over heating....
- Engine Stall and Limp mode problems, I NEED YOUR HELP!!
- 06-07 tail light trunk button not working
- Get your fuel door lock working for less than $1 and 10 minutes
- Rev motor Oil gauge
- Check engine codes
- 4 Door Sedan Lock and Window Problem
- Timing belt replacement
- Rear crossmember crack
- 250GT parts compatibility
- Water Leaking / Antifreeze odor
- Knock sensor replacement P0327 P0328 P0011
- Check Engine Soon!
- Torque Wrench Set
- Is the actuator interchangeable...?
- Dead battery - could it have cuased these?
- No battery, need to open trunk asap
- brok maf sensor screw
- noise coming from HSD coilovers
- Alright guys, I need your help/opinions
- Throwing Codes P0138 & P0037
- Brake, slip, etc dash lights on
- 2005 Coupe Power Seat Problems
- ECT sensor location
- need new clutch. best aftermarket brand? help!
- Squeeling/Squalling - It all started with a car wash
- oem trans cooler bypass possible.
- Heat Trouble!!!
- clutch sticks to the floor... help!
- Service Engine soon lamp questions??
- Miss in drive at stop 04 G35
- Auto A/C, radio does not work, no climate/radio controls. help!
- No crank, no start. Please help!!!
- Smoking center console after jump start
- 03 G35 Noise
- Thermostat code again!
- P Shift Error and crazy sound
- 100k routine maintenance
- How to remove roof drip molding?
- car not starting after motor build
- Intermittent Dash Lights
- Trouble with Nardi steering wheel install
- Mechanical Key Problems
- 90K Service for 2004 G35X
- AFS light Flashing after new headlight install.
- Car won't start. Multiple issues. PLEASE HELP!!!
- Door locks fail to work??
- running rich
- Is this carbon bad?
- Wierd noise from under the dash on passenger side
- AC fan motor not working? Help!
- Chip
- Electronic cutout exhaust kits
- car won't start
- Idle air volume reset question
- Power window wires
