View Full Version : General Tech Questions
- Low idle/relearn after battery disconnect?
- Navigation 2005 Infinity G 35
- Ecm part #MEC 65-270 C1 vs 23710AC710
- My sunroof won't open/close/re-initialize
- G35 fuel pump
- power mirrors not working help
- Dealership Multi-Point Inspection?
- '04 6mt sluggish
- '05 G35 6MT Sedan - Need help troubleshooting...
- G35 power loss
- Fuel gauge always shows empty
- Clicking/rattling noise while accelerating
- Turning indicator sound, door open chime and lights on chime not working
- Trunk will not open
- How do you test fuel pressure in 04 G35 6mt?
- Dimmer switch including taillights (when headlights go on) not working
- Radiator Replacement
- Trunk emergency rope broke now what!
- '03 G35 Coupe Won't start, no crank, no power AT ALL
- B1129 - Side Module RH - Airbag Flashing
- Couple quick questions about shifting, (easy stuff)
- P1705 Error, No Idea Why
- How to keep interior lights bright when you turn on running lights?
- Sounds when depressing Clutch.. and Brakes..
- 2003 Coupe Gauge Madness
- HVAC Selection/Blend Door issue 03 G35
- GHOST! lights and other elect's come on
- Need help with replica nismo bumper front plate
- Couple Quick Questions HELP!!! - 05 IP Coupe
- Tune Up Time
- Help 04 sedan "awd" dash icon
- Traction control
- Car slowing on downhill coasting ?
- 2004 P0430 and P0420
- P0300 please help
- 2005 G Coupe Maintenance Schedule Confirmation
- Connecting to BCM via ELM adapter
- a/c blower not working
- Clutch bleed clear tubing size
- Oil leaks from multiple locations
- Oil light came on/ with check engine light :(
- Got this pinging sound coming from... (VIDEO)
- '03 G35 Coupe power seat issue -- broken gear housing?
- 2005 coupe struggles to start
- thread pitch
- 600-700 whp 05 g35 coupe
- What is this piece?
- Replacement Air Relief Valve (Coolant System)
- Trunk struts.. Does coupe struts fit the sedans?
- Reset Airbags?
- Too many code errors
- over heating problems. 04 g35 coupe
- Brake job quote.. reasonable?
- How loud is the "howling" of a bad wheel bearing?
- New to the G family, I Need help
- G35 horn not working after getting A/C tested
- Buddy Club Racing Spec Short Throw Shifter (REVIEWS?)
- Random Question - Best site or place to buy parts!??
- IPDM,BCM,Ignition and key, ECU
- (Slip light VDC light Off) keeps coming on
- Drivers side window is not secure. Don't know whats up.
- Headlights problems
- 03 Coupe Passenger Window Help (not like the other threads)
- Belts Squeaking After Replacement
- Service Engine Soon
- A/C / Electrical Issue
- Ac line help!!!!!!
- '03 G35 coupe won't start
- 04 G35 coupe issues
- Cruise control not working
- Anyone have part number on this hose?
- Oil cooler leak
- 2004 G35x Key fob Issue
- Rev-up Mrev2 intake
- Found this aftermarket part in my engine bay?
- slip,vdc off and service engine soon light
- Wont go above 1500rpm!!
- New head unit, now electrical problems
- engine stand
- 04 G35 Coupe electrical issue
- Airbag light flashing, reset only temporary
- How can I tell if I have sport suspension?
- Power Steering Leak - Pictures inside. Please Help.
- yo
- All ports dirty except one? Indication of a problem?
- need help!!!! transmission limp mode reset???
- Please HELP
- SES light on a 2005 G35 coupe: P1815 code
- SLIP CLUTCH or just tires??????
- Help....VDC & Slip lights on....
- Car Wont Start (Have Searched)
- The G35 air/fuel mixture issue
- help with heater control circuit low
- g35x noise .. first starting only ( include videos)
- Help !! Weird sounds , ticking
- Whirring / whistling at idle or coast
- Help... Idle issues
- AT 5th gear bypass?
- 06 G35 Engine Knock/rattle HELP!!
- Umm please help :'(
