PDA
View Full Version : General Tech Questions
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. How to reset onboard computer mileage counter
  2. Cruise light wont go out
  3. brakes while doing u-turns
  4. Help. 2005 g35 coupe ECM (IPDM E/R) plug E7 wire colors
  5. Stock exhaust pipes material?
  6. help rear diff OIL??
  7. No interior voltage
  8. Error Codes
  9. 2007 g35x no crank no sign of power at all.
  10. Faint Rattling Noise from Front End in Acceleration
  11. TPP APS limp mode 2122 code troubleshoot
  12. 2004 G35 radiator fan doesn’t cycle off
  13. HID conversion??
  14. Sheared off tow hook license plate mount post
  15. heater core could be the last straw...
  16. Oil everywhere please help
  17. G35x Snow Mode
  18. Electrical wire plug from MAF Sensor
  19. Purchasing Ignition OEM Parts from Ebay
  20. p1078 sensor exhaust valve timing control position, is it supposed to have oil on it?
  21. smell like rotten vegetables
  22. Spark Plugs
  23. Engine swap help
  24. Anyone know the name of this fuel hose?
  25. LS1 auto swap, transmission speed sensor
  26. Vq35de wiring help 2003 sedan
  27. Vq35de wiring help 2003 sedan
  28. 2 codes thrown?
  29. best short throw shifter????
  30. Shaky Issue
  31. Service engine light 2006 coupe AT
  32. Gauges dead after uniden hardwire (need help)
  33. Battery Died and Hood Won't Open
  34. Car won’t turn over HELP!
  35. Misfire on cylinder 5 tried everything I could think of
  36. Pin 101 mod. Plug bay empty!
  37. Vibration after new axles and bearings installation
  38. Broken compression rod Stud -Gktech Angle Kit
  39. QX4 All Doors Will Not Unlock With Remote
  40. Problems with Lights
  41. 2005 G35 Auto - P0021 and P0011 - Everything "Usual" thing to expect broken is fine
  42. Problem ID / Oil leak source
  43. Email Signature management for Office 365
  44. Drivers side mix door actuator wiring
  45. Need. Help with ac line name
  46. Drivers window goes up when door is closed
  47. temp gauge not working
  48. SRS & CEL Stuck on
  49. My G lost all power as soon as I turned my engine off
  50. Budget tool recommendations for a new mechanic
  51. Weird noise
  52. Sedan's wheel hub for coupe
  53. How much gas is needed to put on full when the guage is slightly below a ¼ tank?
  54. ProEFI Tech Question Please Help!
  55. No Automatic Rev Matching
  56. 04 g35 man cranks wont start
  57. Tiptronic issues 2004 Stagea V6
  58. 2008 G35x not blowing air, new member please help
  59. Oil leak
  60. She cranks but won’t turn over
  61. Passenger window
  62. g35 radiator leaking ?
  63. Pls help
  64. 2004 Infinity g35 Severe electrical issues won’t accelerate
  65. Double Din question
  66. VDC Sliding
  67. Please help! What is causing this rattling/vibrating noise
  68. Steering Position Sensor
  69. Running lean I think?
  70. G35x transmission clicking while deccelerating
  71. G35 rough idle, lack of power, exhaust note changed
  72. Where is the EVAP Vent control valve on G35x-2008
  73. P2128 / p2123 please help
  74. Airbag Light After Recall, Pulling The Code
  75. G35 stalling on warm starts!
  76. 2006 350z/g35 ECU problems
  77. 5at manual mode issue
  78. Need help with immobilizer
  79. 06 g35x
  80. Engine swap
  81. Over heat on twin turbo.
  82. Would my car be in km or miles?
  83. Please,anyone who can try to figure out whats wrong with this car
  84. Coolant leak
  85. Gauge cluster issue (odometer)
  86. Windows and door locks unresponsive to internal buttons
  87. RCA Inputs
  88. 2003 auto g35 will oil cooler help in any way? Is it worth it?
  89. Limp mode
  90. Broke something that im unfamiliar with
  91. Need Some Ideas...
  92. Running the p0300 code!!! I really need HELP
  93. 05 g35 auto trans replace. Motor won't rotate after install
  94. 2007 g35x awd 4dr
  95. 2003 G35 coupe CRANK BUT DONT START PROBLEMS!!!😵😵
  96. Having weird electrical problems
  97. Who knows what this might be?
  98. The ac coming hot in 61f
  99. Need Some Advice...
  100. Aftermarket steering wheel; air bag bypass?
