PDA
View Full Version : General Tech Questions
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. 07 g35x cranks but won’t start after white smoke and loss of power at pedal
  2. G35 not fueling all the way
  3. VDC and Slip Light (Brake Fluid Perfect)
  4. G35 problems. Assuming electrical. Help is appreciated
  5. Clutch pedal issue
  6. Will Custom Front Bash Bar Pass Inspection?
  7. GPS screen
  8. Won’t start when warmed up to operating temps- HELP!!!!
  9. Power steering pressurized hard line leak
  10. Bumpy ride
  11. New owner in Eureka MO, need some help
  12. Replace Crankshaft Position Sensor now or wait for it to go bad?
  13. HI! new to this forum. Need bolt thread help
  14. 2003 reversing lights fuse location
  15. G35 in limp mode.
  16. G35 coupe problems
  17. Looking for bodykits for 06 sedan
  18. ECM or Power Steering Control? Thoughts plz...
  19. 2007 g35
  20. New member ....needs some help.
  21. Odb code p1111
  22. New guy needs some help.. ticking/knocking LOUD
  23. Rattling noise at cold start
  24. Flashing service engine light
  25. Trunk won't open(not electrical)
  26. Infiniti G35 High beams electric problem
  27. Dead battery
  28. G35 Cranks but doesn’t start.
  29. VDC not working at all
  30. Halo lights problem
  31. 05 5AT Coupe. Slight "jerk" at idle. Any ideas?
  32. Rear brembo brake caliper to stock caliper
  33. What is this noise?!
  34. Brake pedal opens trunk??
  35. Valve cover replacement to radiator
  36. Replace engine? g35x
  37. 05 6mt issues. Help please.
  38. 2005 Vq25Hr
  39. Need some insight on a problem
  40. 2008 G35x cruise control
  41. Slip vdc light on hard shifting a/t ..
  42. G35 Crank but no start
  43. 03 G35 U1001 u1000
  44. Vibration and hum when accelerating
  45. Throttle body cleaning
  46. 03 G35 Sedan U1001 and U1000 code please help.
  47. Help!!
  48. AC Changes from Recirc to Fresh with Hard Accel
  49. 03 G35 Sedan A/T Cont Fuse Constant Blowout
  50. 2004 coupe has trouble starting
  51. Engine noise help
  52. 05 G35 Coupe Windshield Wipers
  53. Door lock issue
  54. My ignition key stuck infinityg35
  55. Camshaft sprocket oops?!
  56. G35 missfire (tried everything)
  57. Parking lights won't turn off
  58. Oil Dipstick?
  59. Why are my windows doing this all of a sudden?
  60. Airbag wiring harness
  61. Gordgee Grounding Gear Ground Wire Install Guide?
  62. First Gen HR Swap Q&A
  63. Lost my keys then found them now car is locked out!!!!
  64. Water in passenger side floorboard
  65. Time to start mods
  66. Rough transmission shifting
  67. 06 Coupe no speedo
  68. Window lips
  69. Fluids replacement - 2005 G35
  70. Passenger Side HID Projector Vibrating
  71. What can you tell me about my alignment?
  72. Newly Rejoined - NEED COPY OF SxExCx Grounding Kit Install Instructions!
  73. New member fl.. bike rack question
  74. *pulling hair out*
  75. Get it or pass?
  76. Gas gauge issues
  77. Will unlocking a 2004 G35 Coupe with the key trigger the factory alarm?
  78. Power locks went out at the same time, interior switch and key fob both don't work
  79. Turn signal works but parking lamp does not
  80. Several issues with a resurrected g35 coupe
  81. Alarm/auto starter installer messed up my wife's g35.
  82. Need help ASAP!!
  83. Need Serious Help.
  84. 04 Infiniti g35x
  85. Release bearing replacement
  86. fan relays
  87. New accelerator pedal position sensor problem
  88. ** battery drain **
  89. Rat ate my wires! Help locate wire position.
  90. Identifying air filter?
  91. P1186
  92. electronics issues-instruments panel and ABS pump running
  93. Door lock and trunk issues
  94. 07 g35 into 04 g35
  95. Idler tensioner pulley
  96. Ac stuck on 75f.
  97. 04 G35 sedan gauge cluster failing
  98. Oil dripping as car is running. What could it be? 04 G35 Coupe AT 180XXX Miles
  99. Timing chain tool
  100. Exhaust
