- hit 40k :(
- Up the Weight ?
- Sport Wheels!
- Where can I buy the "INFINITI" letters for the back of the G?
- car is in the garage!!!
- Any meets in the Northern Virginia area?!
- Side markers dont blink!! But they come on!
- redline coolant additive ?
- Beater
- Squeak in front passenger suspension
- Alignment = Toe set to zero?
- Anyone attending Import Alliance at LP Field this Sunday?
- water rushing sound after install of Motordyne spacer
- dry carbon
- nismo bumper question
- Wierd grinding noise???
- throdle sending unit??
- Got rear ended =(
- Front Strut Brace
- Best side skirts for aggressive drops??
- Pics of my favorite pass time!
- Upgraded to Audi S4
- "BEWARE" Do Not buy Parts from "R1ricer"
- G35 04 Coupe with 17'' Rims Winter Tires
- Fog Lights & Hi Beams Same Bulb?
- problem with cluster . Help!
- clearance lights?
- Sportmax 962's on DG coupe
- HELP! Throttle cut out?!?
- Team name suggestions?
- new g35 buyer interested in comments about 03-05 g35 coupe
- G35 coupe in Snow?
- Its time for new tires.... Help.........
- bad night.
- F1 Style Mirrors???
- My window will not lower when i open my door???
- What exhaust is this?
- How much should I pay for tires? 275 30 20
- I'm never gonna give up my G35 and this is why...
- Extreme radiator leak...
- Should I trade?
- Interior color change?
- Brake pads for the brembos...
- Work Vs XX or Varianza T1s?
- well it is about that time
- Key Fob Question
- Strut Tower Brace
- Tow truck screwed up my g35... I need help!!
- Planning on new paint job
- What spoiler is this?
- Tire Fitting Question
- Infiniti G35 Seat-Mounted Side Air bags Notice
- Suspension noob :/
- clutch flywheel combo
- Rolling / Drop Chicago shop?
- Gas door stuck shut
- If you are interested in getting a 4080 enclosure better act fast!
- Any Tall 6mt owners out there.
- Finally pulled the trigger on MD spacer
- New clutch time
- What is this piece called and where do I get it?
- Battery problem... Please Help
- 03 6mt with 05 engine Rev up engine mods
- Kuruma Z with dents out of the box
- Serpentine belt??
- how do you get rid of the tire chop on the 03G?
- Need help finding rims!
- Disabling the horn
- interior aluminum trim
- Weird idling?
- 06 OEM spoiler
- Only getting 200 Miles on a full tank, wtf?
- broken hub studs
- My 5 month transformation!!
- I need advice
- Alarm Issue, Urgent!
- Help!!! Electrical problems!!!
- LF: Tips for installing Nismo Exhaust + Berk HFC
- Berk vs fast intentions hfc
- Best type of HFC's
- scratched up my car installing 06 Projectors :(
- How do i remove my 05 g35 radio/ navigation assembly??
- 2006 coupe 50k miles for $16k, good deal?
- New G35 owner want input on mods
- Aftermarket Coupe Exhaust Compilation
- buying a Injen CAI. Whats the difference?
- High Mileage Buyers Guide?
- New G35 Owner
- If anyone wanted to see what the overlay gauges look like for 2003-2004 check it out!
- does anyone know what wheels these are on this G?
- Just removed front LP, how to cover holes?
- G35 Demon eyes in dallas
- Last Formula Drift race of 2010 at Irwindale this Saturday [DISCOUNT CODE]
- Selling clear corners w/ bump.
- VDC Off, Slip, and SES light come on when driving
- How to do the rear spring mount mod?
- what's the diameter of the stock y pipe outlet
- 06 lip..
- HELP! oil in intake manifold
- Clutch Fix Spring Removal Today!
