- Cars are pain
- Windows, locks and trunk release issues
- Swapping out window switch and auto functions went away.
- G35 making weird noise
- Slow acceleration, oil on plugs
- 2005 auto g35 coupe
- Coolant leak
- 2007 G35 Track (Leather)?
- Weak spark issue?
- 2007 g35 coupe crank no start
- Dashboard Cover by Cover King or others
- P0303 Misfire, Please Help
- Can I put 1000cc fuel injectors into my 05 g35 coupe
- What would you do?
- Stiff Steering Issue
- (2003 Coupe) A few dumb questions about the radio headunit.
- G35 window and lock issue
- shifted to park while on manual mode.
- Obd2 port not working & no SES light on accessory mode
- Exhaust question- spec d and berk HFCs
- Coolant bleeding question
- Reputable Shop
- Car stalled, cranks won’t start
- Door lock issue- checking with the experts here
- Head Tick on Drivers side
- Cooling fans not working
- Ds02’s clear Brembos?
- Airbag delete - occupant detection system code B1022
- Super odd ticking noise from 2500-~5500 rpm
- Passenger Seat Recline/incline motor...
- Clunk in front end
- Spliced wires behind battery
- Radiator support
- G35 2006 no start no crank
- Spec-D Headlight Shaking
- MSD Ignition 82796 - Blaster Red Ignition Coil
- Need help trying to diagnose G35 misfire
- Motordyne V1 mufflers
- Electrical noise in dash
- Rpm goes down and up under load
- Car in limp mode after a transmission swap help needed
- limp mode, p1122, p1126
- vq35de stalling problems
- Coolant Leaking
- Taillights work, but brake lights don’t
- (06 coupe) power seats / windows / locks randomly stop working
- Purchased the new Z1 intake - anyone tried it yet?
- Electrical problems
- Loud grinding noise and ABS Light
- need diy for crossmember + subframe brace + steering rack
- Thinking of putting cats back on
- 2004 G35 coupe 6mt in limp mode after engine swap with 350z vq35de
- G37 rims on g35
- Loose A-Brace Bolts!
- 03 V35 Coupe Alarm Problem
- Key fob works intermittently
- Anyone materially reduce cabin road noise in G35 coupe?
- Matching fitment with discontinued wheels
- 2003 Infiniti G35 coupe
- Free Hood
- Grill help
- G35 Sudden Total Brake Failure
- G35 Overheating
- VCD doesn’t work / Can’t disable VCD
- 06 G35 coupe seat into 05 G35 coupe
- WTB: Damaged G35 Coupe Fenders (For G37 Coupe Conversion)
- Window rattle after locking keys in car
- Centering Steering rack
- Sunroof Assembly/Track Repair
- What LSD do I need for an automatic coupe?
- Brakes
- Fuse keeps shorting
- Clutch Play - Is This Normal
- CD009 noise
- 05 HR 6MT Airbag light Question.
- G35 Coupe weird sound when straightening wheels after intial takeoff
- Anyone tried the Ruthenium spark plugs?
- Help with the G!
- G35 crank no start
- Car won’t start! Barely cranks!
- 2007 g35 making weird noise
- Wierd nock sound at really low rpm
- power steering solenoid connector
- Reliability Mods?
- 3in Test pipes? (2007 coupe)
- 2006 g35 coupe ipdm wiring diagram!
- what's this noise?
- Auto transmission questions
- Idle/maf issues
- HKS - Real or Fake?
- '07 VQ35 belt/pulley/tensioner squeak
- Blown Engine G35 For $950??
- Cloyes Timing Chain components
- 2007 g35 coup key port
- Need a no drone! Exhaust for 2007 infiniti g35 coupe
- IPDM problem
- Best options for a 05' G35 Coupe transmission swap!!!
- Ecu not connecting with torque app.
- Please help with diagnosis
- Why does nobody tune imports
