- Can you Take CD with MP3's and Copy it to Car Hardrive?
- mp3 cd on 05 g35
- Where to buy double-din finisher?
- Install this week where to route power wire
- Running speaker wire
- Elemetal Designs e9.65i with Orion HCCA 12.2 on pioneer avic F90BT
- WHich Blackbird for Alpine IVA-205?
- How to add smart key to your car?
- Power Pulg in Armrest for Nav Cubby Install
- Anyone install 05+ HU into 03-04 coupe?
- PAC-SWI-PS set up
- Looking 4 trim ring?
- 05 6disc in 03 sedan....will it fit/work??
- Good HU
- HELP, my car electrical system has a mind of its own
- Those who had a gauge LED swap done..?
- Audio Upgrade - 07 Sedan
- Auxiliary Input Adapter
- can i used polks mm in the front?
- Need help choosing which MB Quarts to buy
- Where do you guys mount your crossovers?
- What amps are you using?
- Anyone using the Pioneer AVIC-Z3?
- In the Back Of the g coupe should i put 6x9s or 6.5s
- So Confused about Upgrading speakers HELP
- best price for a PAC AAI-NIS2?
- Anyone verified Bose HU output voltage?
- Any Legit audio shops that do custom designs in socal??
- Question regards to USA Spec PA11-NIS
- In a 06 g35 if u buy a double din will it interfere with the navigation system?
- Newbie Questions - Bose Amp dead - '04 G35x - options?
- Good Speakers to buy?
- So much more then just a stereo "The G" personalized my way
- Ipod Connectors to Bose
- speakers not working
- DD finisher. HELP!!
- pdx-1.600 versus 500/1
- G35 Cd--F3 Error msg
- G35 CD player-F3 Error msg
- 08 G35 and iPhone
- infinity kappa questions
- 07 G35x w/ Premium.....how to use iPod
- Remove the Sirius antenna??
- Repairing BOSE HU
- my new audio setup
- Steering Wheel Control Removal
- K40 Calibre DLP Radar Detector?
- Audio Problem with CD's Only
- Roofmount LCD install
- Anyone use Second Skin Spectrum Sound Deadener?
- Wire Harness Question
- having problems with sound....
- infinity basslink
- New to the G35
- Door speaker mounting depth
- noob question
- Where is the nav antenna?
- noob sound question
- How can I make my steering wheel controls work with aftermarket In-dash?
- Trunk release problems on 2003 G Coupe
- Signal Prossesing ,YES or NO ??( Original HU)
- Upgrade to Touch Screen NAVI?
- subs facing the rear access port?
- Removing Dash and Hooking up Sub
- Can I install a power inverter...
- Double Din Illumination
- Nav and Ipod Q's on G35 '07
- double din?
- Need help with Infinity Reference speakers
- Question for guys with v1 and mikesmount
- after double din install
- ideas for a custom trunk?
- 2003 Driver Power Seat Questions!!!
- factory amp with aftermrket amp?
- Pay for xm?
- Mikes Mount Suggestions
- Which JL audio set up do i go with?
- Signal processing w/BOSE
- Help locating wires please!
- 05 G35x with premium bose, help please!
- Poor Man's Bluetooth (03-05)
- Mike's Mount + Invisicord
- Ipod Factory Integration will not charge my iphone?
- optima yellow top d35
- Replacing non bose head unit with bose head unit?
- What all will i need to install this
- Trunk lid liner removal
- Do our doors leak when it rains?
- Dls vs hertz
- 7" LCD + JDM DD Kit
- XM issue, radio display reads "ANTENNA"
- Correct Low Pass Filter Setting
- Audio Guru's Please Help
- help with bose audio system 05 g35
- Need help with aftermarket alarm/remote starter
- Key remotes dont work properly at longer distances
- Tweeter placement
- Viper 5900 Question
- 04 Ipod kit installation questions
- NEED help with my DECK??
