- LUK flywheel installed
- stock drivetrain
- My Axle?
- About to buy exedy clutch act flywheel, andything else I need to buy?
- 05 g35x awd not engaging, no MIL
- Flywheel bearing
- Flywheel noise
- Is this a Short shifter????
- New clutch
- 04 Coupe: Engine Turns Over But Then Dies Immediately After.
- Need to change transmission fluid..
- Help me diagnose this problem!
- Fidanza Flywheel & ACT Street Clutch / Pressure Plate
- Weird clicking/whirring noises on startup
- Help!! Would Love to Purchase a Stage 2+ Clutch
- G35x gear shift delay with prolonged high rpm's
- AT Check warning with less than 12K miles on fluid?
- Clutch Choice
- 6mt Rebuild???
- Calling BS on Infiniti
- Starter issue
- Rear Diff Mount $1600?
- Transmission issue .. maybe ?
- The common axle click problem or something else
- LS6 swap...
- Worried about missing dipstick
- Tiptronic switches back to D mode at high speed
- 6mt diff and 3.5 gears in 5at vlsd housing?
- Cluth install question
- Clutch chatter went from normal to holy S*%$, NEED HELP!
- Clutch recommendation
- New Clutch Fork Assmebly Needed?
- Which VLSD will fit in my 06 AT sedan
- XTR Racing clutch kit reviews?
- ACT Streetlite clutch
- 2007 g35 VDC/Slip lights, troubleshooting
- not sure the issue
- RPM in 5AT "Jerky" (stuttering) durings shifts
- Neec to get rid of my carbonetic LSD...suggestions on what to replace it with?
- VLSD vs Open Differential Question
- Transmission bounce
- Need advice on valve body
- ACT clutch and flywheel installed - INSANE RATTLE at low RPM
- A/T jump at 25 mph during braking
- Carbonetic LSD whining under acceleration
- Driveshaft click after clutch install
- Throwout Bearing??
- pilot bearing?
- Need a new clutch! Anything good for cheap? Also, Self Install????
- 4.08 final drive to 5AT
- JWT clutch system replacement/overhaul
- Questions about replacing automatic transmission fluid
- 2005 G35 6MT coupe clutch and flywheel
- jwt or oem throw out bearing?
- Ugh.. super annoying clutch problem.
- g35 coupe 6mt clutch pedal snaps to floor after replacing clutch TOB and press. plate
- Competition or Southbend?
- OIL Cooler Kit On a Naturally Aspirated Engine???
- Final Drive Options
- Clutch noise on cold starts
- Upgrade TQ Converter? Anyone?
- Good twin clutch for fi coupe
- First Gear Issue
- 2nd gear scratching. OUCH!
- Normal flywheel chatter?
- Where should the clutch grab?
- What "stage" for a Turbo'd 500hp G???
- which flywheel?
- Speed Sensor Location on 06 G35 Coupe 6MT
- Slave cylinder / clutch issues
- A/T relay?
- Clutch & FlywheelCombo for FI
- Maximum VDC Tire Size Diference
- Transmission Differences between 07 V35 and 03-06?
- Anyone tried this shifter,
- G35 Axle Clicking...Great Fix Video
- Clutch and Flywheel Replacement
- A/T early downshifting?
- having a slight problem
- 06 Auto Coupe Grinding
- Subframe loose NEED help!!!
- Due for ATF change yet?
- Swapping out clutch and flywheel, what else?
- Need Help. TCM/Tranny problems!
- Dealer Warranty Question
- auto transmission lurching in gear at idle engine speed
- Differential Noise
- Is this diff fluid ok?? Need answer asap!
- g35 coupe transmission fluid check MT
- Clutch problems TECH TYPES PLEASE HELP.
- New clutch, cd09, and flywheel. Now clutch feels inconsistent
- 6MT Issues with higher rpms and shifting
- sudden loss of power. motor is not climbing rpms quick. any ideas as to why?
- Need help with Mishimoto radiator trans cooler lines
- Drive belt and Transmission Fluid Changed
- OS Giken vs. Nismo LSD
- Lsd?
- Convert AWD to RWD
- 2005 G35x Rear diff locked up?
- Transmission/Diff Whine??
