- Diff swap Q's
- g35 competition clutch
- Best struts (shocks) for coupe with Tein S springs
- CV axle maybe?
- Transgo shift feeling
- Vortech G- ACT HDSS or HD with 6 puck sprung?
- Just got aftermarket clutch/flywheel installed, are these noises normal?
- Transmission Dilema
- Clutch suddenly slipping
- Master Bearing Kit?
- OEM or replacement trans
- Trans noise help
- help on which is trans fluid send and which is trans fluid return please
- So I totalled my car.
- LSD for V35
- oil cooler help
- 5AT Tiptronic: Shift when I say so!
- when i engage clutch i hear a whirring sound
- Quick Q, what's the FD on the '03 6MT sedan?
- G35 smokes black under heavy accel in 1st.
- LF Shop to do 5at -> 6mt swap- Florida
- HWY MPG Difference Between Stock and 4.083 Gears
- sticking clutch pedal?
- 03 auto transmission problem. help
- 5AT Mods for Road Racing
- Auto to manual swap (different than all the others swap threads plz read)
- Automatic won't shift out of first in cold weather
- Clutch Seriously having issues
- Slip control light staying on
- Replacing one tire on G35 w/ AWD transmission bad idea?
- 5th gear syncro possibly
- Short shifter cup install help
- Good cheap costing clutchkit
- Transmission Compatibility AT
- Shifter just started vibrating really bad
- 3k RPM Transmission Noise
- Kit car transaxle question
- Shifter sitting extremely low. Broken tramission mount? Help!
- New G35 Jerking..
- Transmission Question!!
- Valvoline max life ATF?
- 2004 Infiniti G35 Coupe
- Clutch shops
- transgo valve body opinions wanted
- Throwout Bearing problem
- just replaced oem clutch with JWT. cant get clutch pressure back.
- 2003 G35 coupe p0011 and p0021
- Tranny swap
- Yet another clutch question
- 04 6MT clutch/tranny issue
- Low idle?
- 2003 G35 Coupe Burnt Clutch..
- RJM Performance adjustable clutch pedal bracket review
- DIY: AWD front CV half shaft removal / CV boot change
- 2005 6mt slipping while engaged in 5th and 6th gear
- 2004 G35 having problems
- High RPM's won't shift to 4th
- Clutch, flywheel, throwback bearing replacement
- Forced induction clutch and flywheel selection
- Need to replace the stock clutch...
- Buying a built longblock.have a question
- Maybe you know what this means...
- 08 G37S Auto Trans Sport Mode Problem
- Burnt Clutch and Flywheel question.
- Rod Knock - Vid; Will any VQ35DE replace?
- Reverse slip?
- The "not like everyone else's" clutch/transmission noise
- Mechanical grinding
- 2003 g35 automatically slipping
- 2003 G35 Coupe ATM Transmission Issues
- Axle click - wheel click - easier fix inside
- What is this hole above rear diff?
- lightweight crank pulley
- Sound when engaging clutch -- HELP !!
- Gear Shift Indicator Went Blank - Car Starts & Drives
- Use M35 rear wheel bearing on G35?
- weird sound when i first start it
- Clutch problem. Need help FAST
- 03 5at sedan tranny reflash (rev-matching)
- '03 G35 6MT is stuttering when taking off in 1st gear
- 3.5 vlsd
- Help!! no power to starter motor
- My clutch pedal is stuck on the floor
- Transmission fluid change problems
- Switching from AT to 6MT?
- Loud whining noise whlie acclerating! Helppp!!
- After installation of Transgo engine won't start
- If you guys STOMP on the clutch pedal you'll like our transmission
- how much power is the 03 coupe tranny able to hold
- 370z rear differential vq37
- longer final drives
- Having trouble with the clutch safety start
- tick tick ping sound. Is it the differential or rear bushings
- Timken Front wheel bearing review.
- Clutch fluid
- How much Trans Fluid? Oil Additive in the 6MT?
- Do I need a new clutch?
- problems with a/t gear shifter
- Anyone Else have a TCM / Valve Body Go Bad?
- 04 6MT Weird noise at 1800-2200 rpm acc and decel
