- SFR Twin Turbo Kit
- Planning to go FI
- Gonna be the 1st..
- Need Some Suggestions
- Car not holding power? Clutch slipping?
- What turbos to go with
- How many miles is too many?
- Looking for a good shop to do machine work/ head work
- Single or twin turbo????????
- vortech potential?
- My build part two...
- Cut back of cubby door for gauges?
- Help ASAP!!!!! OIL IN AIR FILTER ON MY VORTECH
- Stillen SuperCharger Hood
- Used Turbonetics Single Turbo Kit
- Powerlab gt35r
- My next ECU....
- bov change?
- FI: we're not in Kansas anymore...
- G35 Twin Turbo Project
- Intercooler Questions.....
- Ok...I'm in!!! (New Vortech Owner) Few q's
- Rev-Up Vortech Oil Change recommendations
- Speed Force Racing claims 476WHP 429 ft/lbs STOCK MOTOR
- superchargers and upgraded rad clearance?
- Question on ECU for Vortech V3 kit
- Boost, boost, boost! Suggestions please!
- FSP: Z34 Stillen Supercharger Installation
- Question about vortech supercharger on rev up
- Vortech V3 complete kit install question
- stillen hood......help
- Strange noise from the Vortech in my G35.
- question on turbo direction
- MPG on G35 Cp with APS twin turbo kit ?
- centrifugal supercharger
- My ongoing APT TT smoking problems
- IS it ok to run stock bumper with a turbo set up?..help
- over heating Problems (headgaskets)
- Vortech install help and venting
- JWT twin turbo VS Greddy twin turbo
- Need help installing gauges for an APS TT Kit
- Something different
- compound turbo
- Vortech V3 Oil Change
- Alternative Stillen Hood?
- Automatic?
- Vortech Help.
- Built Vortech G35 on Dyno Dynamics
- If I Swap Engine, Do I Need Re-Tune?
- Electric Supercharger 5 PSI Vortex...
- Anybody Know??
- How much does equipping your G35 with a Vortech & supporting mods cost? - The Answer
- I need help with my supercharger (i'm haveing issuse with the performance)
- Open dumps or no open dumps
- My TT G35 project
- @ crossroads with my G..single turbo or supercharger?
- vortech dyno sheets
- Feeler Intake for Vortech owners
- myth or fact about piggy back systems
- Would You Go Forced Induction Again???
- upgraded injectors needed for 530BB kit at stock boost?
- recommended method of tuning for TT?
- Superchargers help
- FI Gas Milage Thread! A chance to Brag!!!
- Anyone has an FI X?
- Replacing Vortech pulley help!
- Stillen Supercharger!!! Review!
- Went to the dyno today...weeee...I'm happy.
- Add some more mods ? should I ?
- How does your FI hold up in very hot dense weather?
- finally I'm Done.... i've come to join the FI crew THANKS TO SHAWN @ CHURCH~!!!
- Got a Compression Test Did
- Help: smog check for Stg 4 HKS supercharger
- How Turbo / Surpercharger work
- possible to use stillen sc with stock hood?
- Vortech Help!
- Reflash over Uprev Osiris?
- LS2 350z--10.8@138 9psi/pump Stock axles/suspension
- 3.5l weak point in engine?
- A/F Wideband - Is it really useful ? ? ?
- turbonetics - shim motor mount
- AEM Water/Alcohol Injection Kit
- 400 whp on stock 06 revup for Vortech
- CT turbo install
- Porsche "Variable turbine geometry"
- *** need help tuner says ecu may be bad after reflash w/up-rev*******
- Best Tune for DD-UTEC OR Osiris?
- Sound Performance G35TT Phase 2
- Electric Supercharger?
- How long did your build take? 450-600 RWHP
- My 928 Motorsport Vortech impeller dyno
- STS Turbo Kits?!
- jwt oil pan spacer question
- odd problem arose at the track
- quick! what am i looking at here?
- My 928 Motorsport experience.
- V2 *IDLE coolant over heat*
- Upper/lower Plenum
- My 2004 G35C - Custom Turbo Garage Build.
- Should I supercharge?
