- Jerk while shifting!
- Performance Factory Sleeper Sedan
- Oil Change
- Knowledge needed!
- Hks BoV ssqv Clip
- New STILLEN Stg2 Owner - What else can I do?
- Procharger installed and I'm over heating!!!!
- Greddy profec B spec II
- New Twin Turbo G35 Member In Maryland
- Introducing myself and my boosted g
- Looking for Gauges, (3) 52mm gauges for A-pillar?????
- Powerlab Twin GT37R kit 640WHP @ 10PSI!!!
- Daily driver...
- Performance Factory: New HKS GT-RS Twin Turbo G35
- FI dudes. Intercooler question.
- if you are FI chime in
- Another FI Gauge poll
- Getting a Greddy TT in 2 weeks
- Our Performance Factory tune came with a extra package!
- TN kit Surging
- Issues with valve cover gasket leak
- buying vortech tomorrow.. couple quick questions..
- Attention All Single Turbo Sedan Owners
- Twin turbo g35 coupe 06
- how to loosen belts for stillen sc install
- Big Problem Last Night
- FMIC - Where's your winshield washer reservoir?
- 400HP with Vortech...what needs to be done?
- Finally! installed my TN kit on my 06
- vortech Ticking?
- Can my G35 beat a M6?
- How to change Procharger COG Belt?? PLease help
- Help me decide what should be gauge number 3!?!?
- Joined the Vortech SI ranks
- Greddy TT - Injector Upgrade
- Got A problem.....Supercharger internals went bye bye tonight
- soon to join FI club..any tips stillen guys?
- Twin turbo for $0.00
- boost controller..can i use one?
- Almost there: HKS iS ECU
- pro charger
- My new numbers on 5AT.
- 07 Sedan Turbo kit
- Vortech Cog Belt
- whats your take on the new VQ35HR setup
- Looking for 12psi Pulley for ATI Procharger.
- Vortech SS box and computer
- How to not grenade my tranny when going FI?
- O2 Sensor removed - HO2S1 Heater Code
- twin turbo break-in procedure for stock block?
- Another Greddy TT on a Relentless Autosports built motor
- ProCharger Tuning
- Honda
- Coolant line behind Vortech mounting plate
- Gas mileage increase w/ plug change
- FI crowd, what oil do you use?
- Possible to LEGALY boost in CA?
- Greddy TT - Detonation?
- Turbo?
- Which other gauge and why?
- someone please convince me that FI on a sedan is not1 of the dumbest things eva heard
- well its a start: vortech dyno
- Need help with gauges for TN kit.
- Gauge Pod
- Best turbo kit?
- Spark Plug Gap
- stock flywheel question?high horse power
- 500+ for under 10k?
- 400/350 at the wheels possible with a non-revup Vortech & 3.12 pulley?
- turbo timer
- help with FI decision..yes i searched
- Powerlab ST
- which way would you go..if you had
- MRC tune of SC
- Building it up.
- Turbonetics now offering powertrain warranties for all kits...
- More questions
- 440cc Injectors
- Unfamiliar Territory
- Sticky BOV - Lubricate?
- GReddy turbo install, now no start
- Variable geometry turbos
- single or twin
- Split Second box work for NA?
- Gauges for Vortech
- Timing control box w/Vortech
- Do you think this 3" hose can be stretched to 3.5"?
- Early xmas gift
- 06 G35 Looking For a Turbo Kit
- Stillen Supercharger Nose Cone Pulley
- Idle Issue Please HELP
- MAP Sensor Installation - Anyone?
- Turbonetics single turbo primary o2 sensor HELP!
- Anyone w/ ARC oil pan?
- Vortch SC: Back to stock???
- Venting BOV [ bypass valve ] back into the intake .
- Vortech: cut off at 4k rpms?
- Need Bumper suggestion for STS tubro :)
- vortech impeller speed??
- Forced Induction in Winter Conditions (Canadian Winters :D)
