- Exhaust piping diameter ... Stillen?
- Calling : Stillen Exhaust Owners
- R2c Maxxflow CAI
- 2009 g37 7at
- SxExCx's V36 Grounding Kit
- Question for those with a FI exhaust
- Driver-Side Auto-Up Window Failure
- Exhaust sound?
- stillen exhaust part# diff
- R2C on 07x
- Just installed a Fujita intake.
- Riverside Infiniti
- Another GCC spec-only option
- Castrol Edge vs Mobil 1 Extended Performance
- Osiris price drop in Standard Version
- Help with ECM plz!
- Aftermarket Camshafts
- Samco Radiator Hose kit
- quick question about intakes
- water leaking
- What do you guys think about Greddy SE exhaust?
- G35 30K Service at CarZone Auto Repair
- 2007+ Transmission Dip Stick
- Finally installed the Q300!!!
- Got tranny replaced at 30k.. Do I still need the ATF flush?
- Vacuum/ howling noise
- whats wrong with my friend's car ?
- HELP!!!!! no throttle response
- Invidia Q300 - Review
- Transmission Flush???
- Exhaust Accessories...
- high idle after warmed up?
- Car didn't want to start for 2 minutes? :(
- Which is the "best" exhaust? :official:
- DIY TT install going on ...
- Bullydog GT Tuner or Powerpup?
- Anyone smell??
- Tranny Drain and Fill, 4.7 quarts needed.
- Can you put auto to N while driving?
- JWT clutch installed
- Best V36 power mod for the $$ ??
- Ultimate Mods Lists
- help needed now!! PLEASE
- Dealer tells me German Castrol Synthetic 0W30 oil is too thin!??
- clutch pedal on the ground
- Fujita Intakes and petrol consumption increased
- New HR internal parts
- Fujita SRI vs AEM CAI
- Weird exhaust/engine noise
- PROBLEM: overheating???
- Catastrophic Engine Failure?!
- Quick Question - Is it possible for an 08 350z exhaust to fit our sedan?
- GTM Supercharger Kit
- need a new clutch but which one
- high rpm = warning light
- Should I keep my HFC's on? Chime in.
- RPM shift light.
- do i need a retune with new engine?
- What exhaust do you guys recommended?
- COBB exhaust?
- HKS hybrid filters !
- RPI Ram Air inducton system for G35/37
- Pennzoil Platinum - TBN
- Stillen Catback
- Cooling Problems?
- Anyone interested in working with OPENECU group to develop G35 compatible version?
- Anyone has a COBB ECU upgrade?
- Throttle Body Help Close to Stripping Bolt
- G35 is tapping like a mofo
- Suggestions for MPG without hindering performance
- custom exhaust ppl please chime in
- How are these Dyno numbers?
- Dyno Sheet for my 2008 G35 Sedan
- need chip?
- For those members with HFC's
- Injen SRI installation issues - Need advice.
- Differential and Transmission Fluid Change
- High RPM Squeak !!! help
- Question w/ OEM Coupe vs Sedan Exhaust
- problem with my 6mt
- Ultimate list of engine problems?
- Meisterschaft Exhaust!
- broken axle RESULTS...
- ECU update and reset question
- 2007 G35x manual shift having trouble
- Transmission swap options
- Spacer on 08 sedan?
- Any Superchargers?
- anyone experience with Stillen Transmission Cooler kit
- Are HFC's worth it?
- Takeda (AFE) Short Ram Intake – First Impressions
- 2008 G35 won't start!
- R2C Intake, Fast Intentions exhaust and Dyno tune …
- Stillen Gen3 Intake fittment and pics
- any turbo or sc setups for our cars yet??
- So i was bored after work on Friday.........
- Fuel Injector Service
- Throttle Body Cleaning?
- Upgrading VQ35DE vs. VQ35HR Any difference in actual gains from intake and exhaust
