PDA
View Full Version : V36 General Tech Questions
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12
  1. I was suppose to get an oil change 150 miles ago..
  2. Install foglights??
  3. Just ordered G37 BBK from Riverside.. Few questions
  4. Resonator deleting?
  5. G35 Z-tube
  6. Performance & 19's or 20's
  7. JWT Dual Pop Charger
  8. Buying an OEM grill
  9. Chip
  10. OEM Lug Nuts
  11. Best Mods for Hot weather
  12. Gas Tank Cap help
  13. Proper torque for oil plug w/ new crush washer?
  14. First DIY Oil Change!
  15. Is speedometer reading for 07+ Sedan: Frt or RR?
  16. parking amber lights
  17. 07 Lowering question?
  18. Having trouble with blue tooth
  19. A few questions about the 2008 G35
  20. Sat dead?
  21. What platform is the G35 Sedan built on?
  22. Auto Up/Down Power Window and Volume Control.
  23. question bout fogs
  24. ECU Reset after break in
  25. Airbags indicator blinking with 08 G35 1800mi
  26. Anyone running staggered on the g35X?
  27. 1800 rpms at idle when startup???
  28. 07 Non-Nav to NAV?
  29. Custom sub enclosure for our 07+ sedans?
  30. tips headlights + grill?
  31. ignition wire 12v, parking wire 12v, door trigger wire.
  32. Ignition wire, parking lights wire,door trigger wire.
  33. Anyone do the NAV update yet?
  34. Changing bulbs in headlight housing
  35. FX35 7-speed Auto
  36. 1 or 2?
  37. Computer reprogramming or Dyno tuning for 07+ sedan. Who is doing it & how much?
  38. T10 License Plate Light recommended!!
  39. HELP, wiring schematic, 08 G35 sport
  40. Safest place to jack up front for oil changes?
  41. Who has switched to synthetic oil?
  42. coolant issue
  43. 08 6MT buzzy shifter
  44. Does anyone own the Escort Laser Shifter ZR3?
  45. headlight housings
  46. G35S6MT Oil Consumption
  47. SATISFACTION CAI - anyone seen/heard this?
  48. Alarm Aftermarket, 2008 G35,which one ?
  49. Turning off laser for ICC/Preview braking
  50. For those with tinted windows and nav
  51. Pilot Bearing?
  52. Tanabe Front Sustec Under Brace
  53. Auto Trans at 40 mph
  54. Washer Nozzles
  55. VDC/Slip Lights
  56. somethings wrong with my g
  57. ECU Chip
  58. What is the centerbore/bolt pattern on the 08 g35x
  59. overlay fitment???
  60. Alignment Specs...
  61. Journey on Eibachs
  62. Poeple need to explain the 5AT a little more.
  63. 2 questions (HP/TQ gains related)...
  64. Stillen Knows Their Stuff
  65. GAS OCTANE vs MILEAGE test results? (only data, please no opinions:)
  66. Power source?
  67. I just got my G35x, LOVE IT, but HATE XM, I need Sirius...
  68. noob question
  69. Lame fan, A/C question
  70. skyline v36
  71. Another Spring/Alignment ?
  72. Mirror Covers w/ Signals /// Blacked Out No Emblem Grill
  73. Blinder m20 Install
  74. Lug Nuts - 22mm or 21mm
  75. Anyone upgraded their Nav. DVD since purchase?
  76. Need Help removing steering wheel
  77. Stainless Braided Break Lines
  78. how to level the headlight on the 07 sedan?
  79. Biggest lip (3"-4")
  80. Will 20"s fill the space?
  81. ECU 'reset' by disconnecting battery?
  82. Latest Autoweek Drivers Log 08G35x
  83. Formula One...LLumar...3m?
  84. my car so low!!!!
  85. I need to tap into the blinkers. Any suggestions?
  86. TPMS Question:
  87. OEM sport pedals kit???
  88. ITB07-007 (tapping from dash) - Anyone experience this or have it fixed??
  89. Newb G35S owner -- what's the easiest mod to start with?
  90. Disassembling armrest/center console
  91. Test Pipes available for the 2nd Gen VQ35HR?
  92. how to clear gauge cluster MPG and Time
  93. small quistion
  94. Wheel Lug Torquing?
  95. there is no quality turn key solution for a supercharger still??
  96. how reset Intelligent Key warning light?
  97. Spring Installer Recommendations: San Diego
  98. How do I remove the exterior mirror cover?
  99. Sport model owners please chime in...
  100. How Turn Off The Airbag Light G35 Sedan 2007?
