PDA
View Full Version : V36 General Tech Questions
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12
  1. Paddle shifter or True 6MT???
  2. 2008 G35 - Tires concern
  3. Max Temp Gauge in Slow Traffic...in WI Winter???
  4. Where do I start to paint front grill?
  5. Should I fill up my loaner with 87?
  6. 5AT Transmission Faluire?
  7. Uprev question
  8. *****got car back from autobody shop and now it wont start after bring it home!!*****
  9. Car won't start
  10. Whistling noise '07 G35 Sedan
  11. Engine is overheating
  12. Automatic transmission fluid change....help me make a diy
  13. 08 Sedan
  14. ABS, VDC, SLIP lights ON and no power on G35
  15. Climate Control issue.
  16. can i get your vin
  17. 07 infiniti g35x VDC & slip light stay on ?
  18. Oil leaking?
  19. TPMS light
  20. problem with some "idiot" lights
  21. Shifting from the stick is getting sticky
  22. Escort 9500ci and Cruise Control
  23. Xenon light keeps going off
  24. New PIAA Forza Hybrid Wipers - Question
  25. 7 months warranty left - thoughts?
  26. Compact Flash
  27. restart Pc for infiniti G35
  28. Battery is dead... how-to replace?
  29. 38000 miles on my 2007 G35x--do I need to do some special service?Tranny fluid flush
  30. Can someone help me out with this issue?
  31. Help! Gap in window seal causing wind noise...
  32. Wipers
  33. What Make is the Windshield Wiper Blades?
  34. Are There Recent TSBs for 07 Gs??
  35. Maintenance
  36. Windshield clicks and pops
  37. engine oil
  38. G37X sedan height
  39. 2008 G35-S Sedan with burn-off smell.HELP!
  40. wheel hp vs engine hp
  41. Question about idiot lights
  42. harnest like wire underneath car? anyone have knowledge on this?
  43. 2008 G35 Navigation System
  44. Washer Nozzle Adjustment?
  45. How to reset the Lock button with 1 honk?
  46. Gear Grind with Paddle Shifter
  47. Will the warrenty cover noisy windows?
  48. Seat Memory Failed
  49. Super Senesitive Car Alarm
  50. Noise when driving...
  51. dash displays service engine soon
  52. torque down wheel spacers? help please..
  53. car starts when cold but not when hot
  54. Exhaust Problem after Lowering G
  55. Maintenance required battery...
  56. low rpm, low mph surging / bucking
  57. keyless entry system button not working
  58. SES light. what to do!?
  59. GTSpec Strut Bar or Intakes?
  60. keys locked in my G
  61. Question about cabin filter
  62. Key fob reprogram issue. Need help!
  63. Clicking sound coming from right wheel well
  64. I have a couple of questions about the new G
  65. Anyone try Royal Purple Synthetic Blend Oils?
  66. How to fix passenger seat?
  67. Battery Acid? Help!
  68. Over ride front driver's seat from moving back
  69. G35 Sedan aftermarket
  70. incabin air filter question
  71. How do YOU make your G35 Sedan faster?
  72. Trac and Slip light on dash sometimes when i start car
  73. Which first.........
  74. Couldn't they make it a bit easier.....
  75. Castrol 5W30 over achieves.
  76. a window problem
  77. 2007 G35X Wiper Blade Part Number
  78. Two Issues
  79. OBD location
  80. modding my g35, need some suggestions
  81. Airbag light flashing
  82. Belt Ticking and Low Tone Noise...?
  83. Infrared thermometer + Driving = Fun
  84. Oil Change Interval
  85. need thread size
  86. Rear License Plate Lights not working
  87. MicronAir In-Cabin Air Filter
  88. Passenger Side Airbag Turns Off Whenever My Girlfriend Rides In The Car
  89. What do you guys think?
  90. draining battery ploblem
  91. Car got broken into... Need some info
  92. Where can i tap for ignition?
  93. A couple of how-to's
  94. Who Uses Synthetic Oil in their G ??
  95. Re-setting
  96. Two G Drivers needed (RPi)
  97. noob question, how to remove windshield wiper blade?
  98. Car barely drivable, no power, barely moves
  99. Tread Wear - Bridgestone
  100. SES Light
