- Coolant Leak From the Reservoir Side
- my car got lowered?
- Help Finding A Part
- 08 HR Y pipe or Megan Y Pipe
- G37 rims on G35 coupe Dilemmas!!
- New Crew In Canada
- Fender Bender 06
- Just purchased...now what? First steps
- Missing piece under hood???
- Car pulling hard to the left?
- Aluminum Driveshaft
- '05 59K miles....Extended Warranty?
- Did I just make a huge mistake?
- Slight Loss in Power Steering and faint rubber smell
- heat/ coolant issues..
- Humming Noise from Front of Car
- Coupe Interior 3rd Brake light doesn't work
- vibrations at start up
- Advice on Indy quote for bushings!
- What are some ways to improve MPG on a G35 coupe 2006?
- Can't find many with this problem.
- Zspeed Clutch+Slave Kit
- Window Stick - Cant Close Door - Winter Woes
- Frustrating unsolvable issue
- 2004 g35 bent front lower control arm
- My Transmission Working Right?
- Help! Need to remove the exterior door handle
- 2004.5 TCM DOA - need some help
- 05 Headlights...Replace, or try to clean?
- I turned, the rear wheel spun on leaves and then sputtered and died
- 1st coupe: gym bag/backpack location ?
- 1 week after getting my G its on the back of a flatbed
- VIDEOS Included: Electrical Issue with 04' G35 AT coupe
- AirBag light blinking?!? Also tps tire light on
- vdc off and slip light on
- Loss of oil on my '05 coupe
- Interior Rattle
- Coupe lower engine splash shield...
- Question Will Fog Lights From a G35 05 Coupe Fit on My G35 07 Coupe?
- Which Suicide (steering wheel) knob?
- Reverse click issue. .fix or live with it?
- Timing chain grinds after oil change
- weird noise on start up
- 215/55/r17 Winter setup on a Coupe
- What brand of oil youse on jwt pop charger filter
- Belts squealing after being replaced and on idle overheating
- Newbie...Rust on rotors....live with it?
- Help! G35 revvs high into 4th/5th gear 40-50mph - transmission or flash fix?
- Sad day for my G35... aka Stella
- First coupe ....Live in North...What is your 2nd car?
- About to pull trigger: '05 coupe..Insurance cost?
- 06 Drivers Side headlight issue
- Service engine soon/vdc/slip light
- 06 g35 coupe airbag will not stop blinking (will stay for most a day after reset)
- Catalytic Converter hole?
- ECU coolant temp sensor location?
- Ivory Pearl color matching?
- 04 G35 Coupe Cat Replacement
- Cheap rear shocks for 05 sport suspension coupe
- Unresolved abs/vdc/slip issue help!
- What is the most ricer thing you have done to your G35 and regretted?
- 6MT Bucking/Stuttering/Hesitating Under Acceleration REWARD!
- tranny wont go into reverse... please help
- what's this weird sound?
- Help spring issue
- Smoking from exhaust and smells like oil
- Bogging at Launch
- 07 Coupe passenger recline/forward seat switch
- Questions about window motor and regulator
- bad sound coming from front wheels *help*
- Looking for a Momentum Performance Exhaust
- Impul Hi-Power control unit
- headlight projector mod?
- Bad gas mileage after new plugs?
- Painting Stock Rims Black. Opinions?
- cracked headlight lens - HID bulb issues ?
- Need help deciding.
- Uprev Tune or Megan Exhaust? - 04 Coupe 6MT
- Need help!
- No handbrake
- Fbo
- Rough Downshift In Manual (5AT)
- Auto Transmission
- just got to compare our BMW 330XI (RIP) and our G35 Coup
- HeadLight Assembly
- HELP me make a decision pls
- What to expect? 04 G35
- What Color?
- Bump in carpet on passenger side floor?
- Is the valve body IN the tranmission?
- JWT Clutch and Flywheel install.....WTF is this mushy grindy feel and sound?
- Need Help! Steering wheel control
- 04 6MT feels heavy when accelerating
- car wants to die at idle.
- Engine replacement
- recommended exhaust
- 04 G35 sounds rough when starting up. Seafoam?
- So I took the G to the stealership today
- SSR SP1 Professors STOLEN 10/01/13 ***PLEASE READ***
- So the G fell on me today
