View Full Version : G35 Coupe V35 2003 - 07
- What is the biggest size tires I should run?
- Random Leak. (Help Please)
- Should I get a tune done?
- Wire completely melted/right harness
- 03 G35 alarm chirping at random
- 07 6mt ready for her first upgrades
- Throttle Body ECU relearn not wokring
- Clutch fluid
- A/C noise issue
- Tire wearing on the inside
- Plate Light 06MT
- 06 g35 coupe gas gas cluster not workin
- Urine smell in car after getting out of storage
- g35 misfiring... what do you think?
- who has the lowest mileage g35 here?
- Car randomly died, no gas pedal response
- Magnaflow x-pipe.
- Seatbelt Replacement Question
- Rasp
- Longevity Survey
- Tire size question in 19in rays
- Why does my G make this noise when I start it up from a cold start?
- Is it possible to install an "always on" power outlet?
- Side markers jdm skyline
- 19 inch rays tire cost
- JWT Clutch Problem
- Power mirrors do not work
- How much labor should I be charged to replace both hood hinges?
- Oil change interval...03 6mt with 168k miles
- Hotchkis sway bars
- G35 headlight help PLEASE
- Squeaking from front end during acceleration
- Bought & Built 06 G35 6mt
- 2006 g35 coupe best mods to do? Need advices
- Is it a PITA to put a storage cubby in?
- Trunk Bike Rack Perfect Settings for 04 G35 Coupe with Spoiler
- Help me make a choice.
- New G35 coupe owner - with questions...
- chirping coming from belts at high rpm
- AFE dry flow filter
- Aftermarket or Factory O2 Sensors - CEL P1051, P1168, P1278 and P1279.
- Yakima Roof Rack for Coupe Help
- changed fuel pump and sending unit, but still having fuel gauge problems
- Do 350z seats fit in a coupe?
- Motordyne XYZ Pipe Advice
- Lack of power
- Thinking of doing a little modding...
- Infiniti g35 coupe 2006 fuel level sensors
- NWP Engineering 75mm Throttle Body Kit or Motordyne 5/16" Plenum Spacer
- 06 white r35 build thread
- Looking at a 2004 G35 Coupe in a few hours.
- Boosted G35-Just replaced transmission-Won't Start
- Revup advice?
- How do I remove the puck on the roof
- 03 G35 knock sensor
- 2003 g35..whats better oem fluid or redline/mobile 1 for transmission and Diff?
- White smoke
- P2A03 code again
- 03 g35 coupe started up turned the Car of now it won't start can't figure it out
- G35 Bumper Help!
- 05 G35 Coupe AT HELP!!!
- Problems getting into 2nd gear!
- 2003 g35 coupe manual differential and transmission fluid parts?
- g35 coupe window motor or window switch????
- Slip and engine light
- 03 g35 manual 165k miles getting 10-12mpg City driving
- Driver side window problem, motor, or regulator?
- Weird overheating issues
- G Shutting off and won't start
- Knocking sound coming from plenum
- where is the best place to buy 2jz engine mounts for my G35
- First Time Post
- Smell From Hi Flow Cats
- RIM Color?
- fender, hood, ext: 2003 2 door to 2005
- Best Clutch Kit replacement
- How to fix doors not staying open (replace check links)
- 2003 G35 Engine swap question(s)
- G35 questions 2005
- Replacement Valve Cover
- What power am I making?
- Plenum spacer
- Problem with interior lighting
- 06 g35 coupe overheating
- Two Questions
- VDC Cornering Issue
- Mod suggestions for an 07 G35 Coupe
- Camshaft sensors and crankshaft sensor question need help?
- Which bumper is this one? 06 Coupe
- G35 Transmission Front Cover + Clutch + Flywheel
- Try to color match?
- When taking off from a complete stop, do you blip the throttle or hold it steady?
- Planning on buying this G, Thoughts?
- G35 Coupe Moonroof Issue
- Service Engine Soon flashing 5 times when car is on ACC, but no codes.
- Accidental miss-shift(over rev)
- radiator leaking, cant find solution.
- Newbie needing advice on g35 i have my eye on
- Door Step/Checks
- Dash Conversion?
