PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Need some specs
  2. Motor swap, security immobilizer
  3. HELP! Random loss of power 04 5AT
  4. Vq25det info
  5. Procharger C2 compatibility
  6. What's this noise?!?!
  7. Help! Location of AWD transfer case control module
  8. Torque Converter not unlocking
  9. CEL after header install.
  10. New Engine Install
  11. 04 Coupe 6MT Motordyne TDX V2 & ART Pipes Install HELP
  12. 2004/2004.5 Service Manual
  13. Sprint Booster for G35X maybe obtainable?!?
  14. Oil Additives
  15. Low idle. Normal?
  16. Help me please!!!
  17. Engine sensor and ses light help
  18. Options for Oil Consumption fix for those that out of warranty
  19. Test pipes question
  20. VK45 swap easier than a VK56?
  21. 03 G35 5AT Transmisson problem
  22. LiquiMoly Ceratec-Worth it?
  23. Tuning software
  24. differences between vq35de
  25. G35 coupe
  26. Fluid
  27. Burning smell and smoke: Oil leak onto headers?
  28. Engine lift how to?
  29. G35 Rear Knocking noise HELP!!!!
  30. Oil in exhaust-Turbo or headgasket
  31. Figuring out how much horsepower i have.
  32. HKS DLI II harness or pinout
  33. car stalls while decelerating
  34. seeking your advice on 2005 G35 5AT differential swap
  35. 2003 coupe snapped camshaft! and more need advice.
  36. Is my ecu done?
  37. Help! project car will not start .or idle
  38. 05 g35x tranny question
  39. I need help with these codes!
  40. Another NWP 75mm TB review!!
  41. Engine swap problem
  42. Help! Problems with shifter
  43. Which is better???
  44. Replacing rod bearings on 05 G35 6MT without pulling engine
  45. Nengun
  46. Engine rattle - not heat shields.
  47. 2003 overheating. Thermostat, then water pump now tensioner??
  48. Fuel Pressure too high
  49. Hard Crank
  50. 05 Cabin Heat keeps going out when in idle
  51. Oil consumption advice / buying new
  52. Driver camshaft and bank 2 solenoid
  53. CEL after accelerating
  54. help diagnosing misfire/blinking CEL
  55. Graphite to tanny?
  56. Plenum Spacer Debate!
  57. ac compressor
  58. no power after 3500rpm
  59. Building my motor
  60. Plenum spacer
  61. How to get a Sub 5 Second N/A 0-60
  62. Engine temperature with Vortech?
  63. Changed the transmission and now the car will barely idle
  64. Exedy OE Clutch and Stillen/Aasco Flywheel Review
  65. Burning Rubber Type Smell Thru Vent
  66. Engine swap HELP
  67. Oem green coolant vs blue
  68. Error Codes
  69. Problem with Manumatic D:
  70. APS TT Engine
  71. Kinked 90 dgree supercharger oil return line!!!
  72. change the engine or no?
  73. Watching my oil levels
  74. Car running poorly, no CEL
  75. R&D Factory Valve cover Gasket Set
  76. Think I threw a rod :( What year motors will fit 350z/g35?
  77. Coil Pack bolt hole
  78. What is the Hose from Plenum to Battery Compartment?
  79. Vq35hr 2007
  80. DIY P0171/P0174, Intake, Smoke Machine, MAF, and Fuel Pressure Troubleshooting
  81. New ECM NATS issue
  82. Lifter/Valve tick, how can I get rid of this??
  83. 03 g35 swap questions???
  84. VERY low idle even after ECU reset, only when cold outside. HELP!
  85. VQ35HR running really rough.
  86. P0171 Running Lean Driving Me Nuts! Need some help...
  87. Help with measurements?
  88. '04 coupe throwing codes ????
  89. Weird sound at idle, please help
  90. best way to put fan (ac) on a switch..
  91. 03 g35 p011 and p022.
  92. 03 sedan overheats when stopped
  93. Throttle Body problem????
  94. 06 Oil Leak - No Lift :(
  95. Another SES light question
  96. Can anyone identify this sound?
  97. crankshaft position sensor
  98. Supercharger dyno list
  99. P0021 vq35hr
  100. 03 auto trans
