PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Rough Cold Start - Idles & Runs Fine (Even cold)
  2. P0340 Bank-1
  3. Connecting Rod Bolt Head. What is it?
  4. Oil Change Interval
  5. Suspect a bad throw out bearing...HELP NEEDED!!
  6. Random Misfire mainly at idle, code P0301 Cylinder 1 misfire
  7. 06 Coupe A/T Needs New Wire Harness?
  8. Help
  9. Idling Issues Post Winter (COVID Sporadic Problems)
  10. 2005 G35 Coupe - Ticking noise that matches engine RPM
  11. Engine rattle or ticking noise?
  12. Will a 03 wiring harness MT work on 04 ECU
  13. Junk or Keep Need expert advise! Pictures!
  14. Best non longtube Headers to go with?
  15. Header bolt thread pitch size?
  16. Here is why you cannot replace the driveshaft u-joints
  17. Engine has intermittent hiccups during idle after warmup
  18. Could I swap an 06 G35x motor into an 04 coupe?
  19. Bad thermostat?
  20. All 4 O2 Sensor Circuits High Voltage, Random Miss, Bank 2 Too Rich
  21. Car lacks performance, regains it after ECU reset (and loses it shortly after)?
  22. Check Engine light for Bad Camshaft Position Sensor, then went away
  23. Which radiator for 05 G35 5AT Coupe? Oil cooler?
  24. Coolant open to atmosphere?
  25. AC Pulley Misalignment Squeak?
  26. Engine cuts out
  27. No spark, no check engine light, what to do?
  28. With replacing valve cover gaskets is replacing the valve covers required?
  29. VQ35DE-T needs rebuild
  30. Help! Car dies randomly, complete loss of electricity
  31. SMH not sure what to do next with P0300
  32. Engine
  33. How bad is this?
  34. P1759 & P 1757 (Car in limp mode)
  35. Flywheel bolt snapped wtf do i do
  36. Help with manual bell housing and engine connection
  37. Is there a trick for?
  38. Intermittent no start condition, now complete no start.
  39. P0300 Code SES Light Gone?
  40. Help! 05 G35 Sedan 6MT C1131 P1122
  41. Overheat help please
  42. Engine stand suggestion
  43. Did i buy the wrong engine?
  44. Advanced Camshaft Timing After Clutch Job (2005 Infiniti G35 6mt)
  45. timing components help
  46. Gear oil burning smell
  47. U1001 and P0300 HELPPPPPPP!!!!!
  48. Starting Issue
  49. Piston Rings
  50. No start after timing chain install
  51. No crank, no start 2005 G35 coupe
  52. Sending unit(s) failure?
  53. Need Help ASAP.....
  54. OBD2 Mode 6.
  55. P0300 code and cat getting red hot
  56. 2003 VQ35DE Rebuild Suggestions
  57. G35 gets rod knock - what next?
  58. p2128 p2123 Codes help!
  59. 2007 G35 Won't Start After Sitting for 1 Year
  60. Bleeding the G35 cooling system
  61. Help please
  62. Engine suggestions/dealers
  63. 2003 G35 twin turbo fuel pump issues.
  64. Need a rev up rebuild or swap in NJ , will pay $$$$
  65. Valve cover Gaskets Round 2 Questions
  66. Why *not* to use cheap cam sensors...
  67. Car stalls under heavy breakin
  68. Please help! Code P2122 and P2127
  69. Please help, Car sputtering after tune
  70. Engine swap
  71. Mystery Oil Leak??
  72. Cam Position Sensors - Same on Both Sides?
  73. Cold Start Rattle 1-2s long
  74. Oil pressure light
  75. Aftermarket vs. OEM Fan Clutch 03.0 G35 Sedan
  76. P1283 and valve cover
  77. G35 auto trans replacement
  78. Blank gear selector, not shifting or starting.
  79. Transmission type?
  80. Valve cover gasket replacement
  81. Help identifying gaskets.
  82. Auto trans
  83. Engine Swap
  84. Need Some Help...
  85. running rich
  86. Engine, Transmission, and other parts weights
  87. Cool problems
  88. Smoke in harness
  89. Engine swap
  90. G35 sedan throwing codes p0011,p0442 and p0300
  91. Post Engine Swap Slow Throttle Response
  92. JDM vs US 2006 RWD transmission vq35
  93. Rev Hang New to Infiniti
  94. Weird metal rattling (deep loud) noise at low rpm
  95. VQ35HR N/A Build
  96. My build plans!
  97. Looking for some help for a friend
  98. Who makes this plenum
  99. Misfire codes
  100. What are these two tube/wires for? The previous owner just cut them.
