- Annoying Noise when A/C is on - Help
- 06 Rev-Up Sputtering Under WOT. Code is "Multiple Cylinder Misfire" What's the cause?
- Engine Whine - In neutral or in gear, but goes away when clutch depressed
- Rear subframe Differential Bushing NorCal
- HKS Beginners Guide to Tuning
- adjusting tension on drive belts now car wont start??
- Need Fuel Pump Rubber Grommet Please Help - Cant Locate Anywhere; Stage 4 Stillen
- Motor Dies after cold start (unlessed rev'd)
- New JDM HKS ST Build but what are these parts ?
- Found Oil In coolant when i replaced radiator
- Nissan 5.6 litre swap
- JDM Oil Consumption and Warranty Company Screwing me over
- That engine rattle ]:
- engine making clicking sound
- how much hp can the stock heads/cams handle?
- Transmission question
- G35X buzzing rattle from engine area
- Changed Radiator Now Temp Gauge going Up/Down as Rpms Increase
- G35 03 coupe HKS single exhaust video! (short rev clip)
- Pulley bearings going bad??
- Cosworth oil pump... worth it?
- Burning oil
- What upgrades work well?
- Turbonetics Kit Upgrade Help
- Known Oil leak into cylinder
- 03 G35 Nitrous Window Switch Install
- new engine due to oil consumtpion but dissapointments.
- oem clutch/jwt flywheel to act hdss/jwt and its easier???
- Stock pressure plate with ceramic 6 puck ok??
- Springs Vs. Coil Overs
- Performance Chip
- engine help
- Thump when starting engine after sitting
- Rubbing/grinding Noise after Clutch and Flywheel install ('05 G35)
- CAN communication code help after fan install
- Removed my resonator, No BS it helps!
- 2003 Overheating when driving (Any speed)
- Codes p0303 and p0340
- P0345 Engine Problem: VTC Sprocket or Pulley
- O/C showing at 89k miles, options?
- 2008 g35x pumpkin in a 350z
- Oil light
- Mishimoto Power Steering / Coolant
- Engine Oil.
- Need help with engine swapping 05 G sedan
- Valve cover gaskets need asap
- Sedan Walbro 255 Regulator/Swirl Valve Mod.....
- Swap vq's z to g35
- 07/08 G35 Rear Axle on 03 G35 Coupe
- slip light
- My 03 G35 is sick :(
- P0011 Code Help - '03 5AT
- Clutch slipping?
- rev up vs non rev up
- P1283 - Air fuel ratio (A/F) sensor 1 (Bank 2) lean shift
- Chain tensioner or sprocket? vid included
- Review for RJM Performance Clutch Bracket Kit
- Cruise control does not engage
- Clutch Point after JWT Flywheel / ACT Clutch Change
- New member. Need advice on valve cover job.
- still seeking help
- Electrical fan conversion... where did you get yours?
- HELP! Where does this plug go?
- belt broke.. Car hesitates to start now.. Help
- Help! Car will not start, giving me U1000 error code
- Whiny sound when Cold
- A/T Radiator in M/T?
- Trouble starting and safety mode..but no codes????
- Help with Radiator support clips
- Slow crank, now car won't start
- Clicking noise from engine
- What are these test pipes?
- Drove through high water help! Wont start
- 'Slip' on while driving in rain
- New flywheel/clutch?
- Battery bolt nut size? Also where to get push in clips
- About To Hit 100k miles
- Hit a sewage drain thing today on the road...VDC/Slip light went crazy
- P0011 - Valve Timing Control Solenoid
- Newb with questions about EVAP
- Motor swap help
- engine doesn't turn on, only clicking sound... pls help
- Best order for Engine mods
- question with pulley crankshaft
- 6mt question
- Changed the plenum
- UpRev Tuning
- Misfire with no code and new coils and spark plugs
- Cable to the radiator fan
- GK Industries Filters
- G35 with NEW engine, does car value go up?
- Haltech tuner near Ottawa ON
- just barley turns over
- lifter noise when starting engine
- high pitched whining when A/C is on
- Pure One Purelator Oil Filters on sale!!!
- Old gas = Low Dyno #'s...
- Quick exhaust question
- Accel Spark Plugs
- Slow water leak from undercarriage ?
