PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. 2005 G35 Transmission
  2. V8 swap passing emissions thread
  3. Valves Covers Wich Route ?
  4. Time for New Valve Covers?
  5. Oil catch can solved one problem, created another.
  6. automatic tranny rebuild
  7. Radiator Leak?
  8. P0158 engine code thrown!?!
  9. Did have CEL - PO340, fixed that, but still slow to crank..???
  10. 1400 hp Wankel engine.....I want one!!!
  11. need help asap with blown motor
  12. cranks but will not start
  13. g35 backfiring ?
  14. Hey, Y'all who wants some spark plugs?
  15. Replacing 2003 G35 Coupe Engine and Tranmission. Need Help Matching Parts
  16. Vq35de
  17. 2004 G35 Startup clanking noise
  18. Help blew my motor looking for correct replacement
  19. Radiator replacement - cannot attach fan shroud
  20. Transmission problems?? Car stalls, dies while driving, not cam/crank sensor
  21. G35 Pulleys for the serpentine and fan belts
  22. whats the weak link?
  23. Help please: Transmission fluid
  24. Pistons and Rods
  25. slave cylinder
  26. Opinion needed fuel return
  27. Rough start after car sits :(
  28. Looking at buying a oil catch can
  29. Sucked water through turbo
  30. Need some info on my aftermarket clutch.
  31. Few issues with my 03 5AT, Possible upgrades?
  32. Need help with misfires. P0300 and P0304...
  33. Oil Leak - Back pass the oil pan
  34. Clicking Noise at 3k-6k RPMS (With Video)
  35. Need Help!
  36. Bank 1 and Bank 2 Camshaft Position Sensors identical? 2005 Sedan 6mt
  37. Very high RPMs at 65-80 A/T
  38. Trouble After Upstream O2 Sensor Change
  39. UR pulley set worth it?
  40. timing chain kits?
  41. g35 clicking noise when accelerating
  42. Any "Limited Slip Diff" Guru here ??
  43. Kg/Lb Reduced G35
  44. Engine quits unexpectedly
  45. Trouble with Mishimoto radiator install
  46. fuel return system importance
  47. Help! Oil Dipstick broke off inside How to get it out?
  48. 03 coupe won't start
  49. how do i replace front right axle on my g35x
  50. Oil Consumption Question
  51. 03 G35 Coupe revs to about 1500-2000 then takes off?
  52. Motor swap help.
  53. Default factory timing advance
  54. G35 very bad idle issue, no acceleration.
  55. I think my motor is about to die or something needs to be fixed
  56. G35 coupe running rich
  57. Wot wire location
  58. I need help installing a idler pulley delete kit.
  59. Fully Built VQ35 by me
  60. Need help getting my engine started
  61. 11:1 Compression Pistons and Octane
  62. pLEASE HELP
  63. Please help me find the engine knock
  64. Catch can set up
  65. Thoughts on light weight flywheel.
  66. Trying to find the cheapest engine that will hold 500whp
  67. Can the O2 Sensor bank1 Cause Smoke?
  68. High Milage 05 G35 Sedan AT - Light Mod Questions
  69. rattle when revving engine
  70. Weird Smell coming from intake manifold
  71. lower oil pan
  72. Dome light stopped coming on with door opening - the sliding switch was the problem.
  73. Pinging? Ticking? Clicking? Turns out it was the starter
  74. Service Engine Soon/SLIP light
  75. what kind of o2 sensor? 07 g35x sedan
  76. Receiving New engine - Average cost of Install?
  77. 04 G35 with ticking shim bucket Help please
  78. Plenum spacer install problem
  79. Vacuum Leak
  80. Please help car overheating
  81. 04 g35 MT, RPM at 800 even on neutral, help!
  82. Can Catalytic Converter Cause Grinding Noise on Startup?
  83. Just got my first "new" G35! How to get it to run like new?
  84. Budget Motor Build - Thoughts / Help
  85. Head Gasket Replacement,
  86. Weird starting issue 6mt
  87. Location for fuel pump fuse relay?
  88. headgaskets or something simpler
  89. convert heads to revup
  90. Changing transmission fluid after 60,000 miles on current fluid
  91. Engine Swap? Which engines fit?
  92. ZEX Wet kit on high-miled VQ...?
  93. Changed Spark Plugs, Lost Power
  94. Anyone running Rotella T6 Motor Oil
  95. VDC off and slip light both came on
  96. Help: P0335 from hell - what can it be?
  97. 05 G35 Overheating help
  98. Rough idle after 3.5" Furookie
  99. Radiator/Coolant Issue
  100. skyline 350gt coupe. Electrical plugs near auto gearbox, where do they go?
