PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Stroker Kit
  2. problems with RPM after installing popcharger and z tube
  3. Blue UR Crank Pulley Set
  4. private classifieds
  5. 350Z to G35 coupe Fujitsubo exhaust
  6. G35 vs 350z
  7. Unlimited Tuning Y Pipe
  8. Performance Shop
  9. 03-G35C to 300hp??
  10. NEED exhaust tips - where to find?
  11. VRT built car and motor with a JWT TT kit
  12. Wierd Clunk Noise on Coupes....
  13. burn Motor Oil
  14. 315 HP Sedan w/ bolt-ons!
  15. How to Clean MAF ???
  16. My latest oil analysis, and from the last 2 1/2 years as well
  17. Turbocharger for Automatic
  18. How much oil to spray on JWT Popcharger?
  19. Belt noise
  20. questions about the Motordyne Copper TB Heater
  21. Just ordered...
  22. Un-official/stolen pic of MREV!!!!!
  23. 300hp engine,stronger? Not really...
  24. Will these work for the G35?
  25. What do you guys think?
  26. Synthetic Oil....the answer
  27. Anyone tried this turbo?
  28. Strup Headers really worth it 05C MT, or Tony's MREV?
  29. Pulleys
  30. built engine consists of???
  31. HKS Legamax vs HKS Hipower
  32. Half Covers
  33. Kinetix cats added +7hp/+22tq to my 05 6MT Sedan
  34. Stillen Engine Dampener
  35. ME Motordyne Plenum Spacer for sale
  36. We've talked M3, what about the 545i?
  37. anyone have rpm problems after installing z tube and popcharger
  38. 2005 or 2006
  39. No aftermarket cams on '05s?!?!?!?!
  40. Recent Blackstone Oil Analysis Report
  41. Skunk2 plenum
  42. Best mods to put for an N/A motor ?
  43. Second time my battery died. Which battery should I replace it with?
  44. I over filled engine oil
  45. Help: Weird noises from the G
  46. Service Engine light?
  47. Engine tick
  48. Hyper Grounding Wires
  49. low temp thermostat
  50. suspension on 06 g35 help
  51. new product 10-13 hp(ANGLED PLENUM SPACER)
  52. Chnaging Radiator Hoses
  53. Better intake=better airflow=more gas?
  54. NISMO Cams & Head
  55. How to change both Engine belts on an 03 G35 Sedan?
  56. OBD based hp/tq curves
  57. Rough Idle
  58. Info on "Rev-up"
  59. What Can I get?
  60. Quick question?
  61. what engine mods to do-auto g35 $1000 limit
  62. Specs and compare of old G35 to new.
  63. Plenum/Spacer Installation Hint
  64. Any actual dyno data on JWT P/C, Z tube, stock, KN?
  65. Question about CF intake systems w/respect to material
  66. Motordyne Plenum Spacer Install Question
  67. VDC Help
  68. Stillen Oil Cooler
  69. leased g35 limits..
  70. how to beat an m3....
  71. Crawford cats cracked TWICE. Help...
  72. Which INTAKE produces the most power and is the best for a 2005 G35X
  73. Is Ur Crank Pulley Worth It
  74. SAE Correction Factor Question
  75. New springs/rims, and bad shake.
  76. '04 G35 DYNO results
  77. im confused what does the z tube due and the pop charger, and y the 06 05 is hotter
  78. help find Vid clip of white G with pop charger
  79. Belt noise in the rain?
  80. High Pitched Sound! Please Help!
  81. hks intake for 05'???
  82. what if air filter installed wrong
  83. Blown Motor for NA mods???
  84. Estimated HP/TQ gains with the following mods??
  85. Every G35 'KP Technologies' Module unmasked and reviewed!!
  86. Reset ECU for better gas mileage?
  87. How often do you reset the ECU?
  88. What does it take to get a G35 in the mid 13's?
  89. just installed nismo CAI, quick question...
  90. Technosquare Halloween Special Offer. 1 day only!
  91. plenum for 05 sedan?
  92. Plenium Spacer? Basic NA mod questions
  93. spacer vs new plenum (cost not a question)
  94. My dog ate my brakes!
  95. aem cai filter!
  96. Camber and Toe
  97. Strange Hissing?
  98. Technical Help
  99. z-tube question..
  100. Injen CAI filter service.
