- Mods and Warranties
- Looking for ground effects.
- Free mods?
- Jet Chips ECU upgrade
- Factory Service Manual
- Aftermarket Modifications - Please Help
- confused a bit
- List of Aftermarket Parts
- Infinit Dealer won't offer Nismo product
- help w/ grounding kit
- High performance pully question
- Technos ECU vs. Crawford Plenum
- Upcoming Japanese Products
- Resetting the Maintenance Reminder?
- Idle RPMs
- where to find pictorial direction????
- My first oil change!
- Competition to G35 ATI charger!
- FIRST TUNE-UP?
- Pulley Set - 8-12 hp/10-14 ft lbs Torque
- Royal Purple Additives?
- ECU really worth it for 6MT owners?
- Impul ECU
- List of modifications
- Stillen Depressing
- Z-Xtreme.com Grounding Kit
- AZ G35 Club
- Succesful Crawford Install :)
- Having to reset the ECU is LAME!
- Sedan stalls with Stillen Intake
- 3.5 Liter Altima making 260 Wheel HP NA(JWT Cams)
- new pics coming up soon
- Under hood detail
- Make your A/C colder
- 350z / G35C Engine Mod Compatibility?
- Battery Relocation-Anyone Done it Before?
- TechnoSquare ECU - Opinions & Facts
- Maintaining Power with Battery Disconnected
- Water Wetter
- Math question about HP and Weight
- no sedan mods- can i custom ?
- Awaiting shipment
- IMPUL ECU??????
- Dyno @ Mossy Nissan
- What mileage is safe and effective to start mods?
- Techno ECU update
- Tomei cams/dyno's?
- Whining/powering-up sound at low speeds
- New G/car enthuisist questions
- Has anyone used stillen pulleys?
- anyone heard of KG/MM springs?
- ECU Reset
- Hyper Voltage System
- Hotwires Add HP!!!
- Dip Stick Blues
- Pulleys good or bad?
- Need Help with ECU
- The whole ECU reset thing . . .
- 1st time at track, ran faster in Auto mode
- Headlight adjustment?
- APEXi SAFC S-AFC Sentra Altima G35 Maxima CHP
- All mods SUCK without ECU
- Mobile 1 Oil Filter Part No.
- Dyno'd 6mt sedan with mods
- ALMS G35 GTS Race Car
- ECU reset and 6mt
- ECU
- My SEDAN has now got the TechnoSquare ECU
- how much would these cost?
- DYNO numbers, coupe vs. sedan
- HKS Twin Turbo and VEILSIDE Kit UPDATES!!!
- G Potential
- what mileage is ok to start mods...?
- Turn signal ticker busted!?!?
- Has anyone switched to Synthetic Oil?
- engine grind on startup
- Technos ECU Dyno?
- OBD II Code Reader
- Technos ECU for G35
- Hyper Voltage System, is it worth it?
- hyper ground kit type s
- What is the best grounding kit?
- Please help with electric radiator fan info.
- will beat an m3 after next mod
- Real carbon fiber one-piece spoiler
- How Light Can You Go?
- Should I put on my crank pulley?
- remote/bcm???
- Is a tech info summary section needed?
- Oil analysis with 7,565 mile oil change
- Mainstream's Project SEMA Twin Turbo Issues
- Pic of Dyno with hp Gains from Grounding Kit
- Twilight Blue Coupe
- Mainstream's Sneak Peek to Project SEMA
- Oil change = HP gains???
- clarification needed
- Best Mod Combo To Date
- Ground wires
- First Oil Change - Impressions
- How to find out what your newest mod will do...
